Took my car to the RR at the weekend.
Its is standard apart from homefries remap and Roose boost hoses.
Results were -
max power 258.1hp @ 5795rpm
max torque 287Lbs/Ft @ 3345
peaking at 1.2bar boost pressure, but its fluttering
AFR 13.6:1 at max throttle, thats pretty lean!
Power curve isnt particularly stable, and drops off at 4750, then goes up again at 4900ish
any ideas guys? 1.2 bar would make me think boost leak, but running lean would suggest otherwise.
Car has had new WGFV, new 710N, new f5dpor plugs.
Results were -
