Smoke!
  • irvind
    • Oct 2003
    • 316
    Smoke!
    Went out for a run this afternoon and just as I was getting close to home again I noticed two seperate clouds of smoke coming out the back! It happened each time just for a few seconds but thankfully didn't give me the full 'Kimi Raikkonen' experience.. ie, I made it back to the pits. Ok, my flat.
    Obviously the car has never ever done this before, the only long-term off-the-road time I had was last year when the ignition coil went and the stealers scratched their heads for six months.
    What is this new devilry sent to test my patience? I need to do Glasgow to Bradford on Tuesday so a fully-functioning engine would be welcome..
    Agh!
    Irvin
    '08-'0?:
    '97 Coupe, Kingfisher Blue
    '01-'08:
    '93 ABY Coupe, Milltek cat-back, Alpine dvd Sat-Nav/Changer
    www.irvinduguid.com
    what colour smoke was it? what state was the engine in at the time?
    • irvind
      • Oct 2003
      • 316
      Em, black/grey? smoke..
      Just coming back into town so the engine was probably starting to get up to temp again. (It usually runs cold, only hitting 90 in town). Apart from that, fine really, nothing unusual!
      Irvin
      '08-'0?:
      '01-'08:
      www.irvinduguid.com
      • irvind
        • Oct 2003
        • 316
        Just checked oil level, it's at the bottom marker though the car is sitting forward at quite a steep angle. Last service was 1800 miles ago.
        Irvin
        '08-'0?:
        '01-'08:
        www.irvinduguid.com
        • Beetie
          • Oct 2003
          • 1517
          Always check on flat surfaces... Also mine chucks out black smoke when ive got a boost leak... I think its something to do with the fueling with the excess air....
          • SteveH
            • 4460
            Does sound like it could have been a fueling problem. Blue smoke would suggest oil burning, so it's hopefully not a mechanical issue.
            91 Modded 3B
            14 A6 Avant Black Edition
            • irvind
              • Oct 2003
              • 316
              Don't think it was blue smoke..
              I'm guessing I should whisk it off to the garage rather than drive about in it?
              Irvin
              '08-'0?:
              '01-'08:
              www.irvinduguid.com
                Yeah it would be worth getting it checked out for peace of mind. Has the fuel filter etc been changed?
                • irvind
                  • Oct 2003
                  • 316
                  Just checked and the fuel filter wasn't changed at the last service, though it had a new fuel pump at about xmas time so it might have been done then, not sure though.
                  Checked the oil with the car on the flat and the level is fine, up at the top.
                  Irvin
                  '08-'0?:
                  '01-'08:
                  www.irvinduguid.com
                  • irvind
                    • Oct 2003
                    • 316
                    Gonna stick it in the garage, too worrying to take on a long drive. Mechanic geezer reckons it might be running too rich. Been using coolant recently too, don't know if that's related. I'm ok at changing wipers and putting petrol in but other than that...!
                    Thanks for the advice again people!
                    Irvin
                    '08-'0?:
                    '01-'08:
                    www.irvinduguid.com
                    • irvind
                      • Oct 2003
                      • 316
                      Latest news is that there's oil getting into the exhaust system somehow, and he suspects dodgy turbo seal. Apparently the smoke is blue, not black as I thought it was, and it's not running rich so the cat is fine. They're taking the turbo off tomorrow so hopefully I'll know more then. He also said something about the ECU 'not recognising boost' or something.. I can't remember his words since it means nothing to me anyway...!
                      Q. Are there one or two cats on the ABY? Seem to remember hearing two somewhere..
                      Irvin
                      '08-'0?:
                      '01-'08:
                      www.irvinduguid.com
                      • Dr H
                        • 1175
                        You have 2 cats on an ABY.
                        If your turbo seal has gone the best and cheapest option is to have the turbo rebuilt. I sent mine to AET in wakefield £260 + vat later it came back like new!
                        Since 1974 AET has been at the forefront of turbo engineering. AET, based in West Yorkshire, England, specialise in new and remanufactured turbochargers, turbo reconditioning, and turbo re-engineering for a wide array of applications — from commercial and passenger vehicles to agriculture, marine, plant, power generation, and motorsport.
                        HTH
                        • Sweeper
                          • 1317
                          • Country: Latvia
                          I also have the smoke. It's smell like a lot of fuel(damn lot) and the car just don't go over 2,200-2400RPMS when i try to accelerate , but when i do this slowly it's accelerating !!!
                          Any suggestions ? Please not expensive ones
                          Vadim.
                          Vadim.
                          • Martynf
                            • 1885
                            Or get a bigger one
                            Martyn
                            www.vagparts.com
                            • Martynf
                              • 1885
                              wish I could F/Fwd the clock a year...
                              Martyn
                              www.vagparts.com
