RS2 Turbo markings
  • Doug_RS2
    • 3847
    Interesting - Would be nice to see how it feels without the RS2 EM.
    Does it have the metal headgasket as standard?
    Are you going to be monitoring intake temps and EGT? Did you get a display made?
    There is a cheap way of at least monitoring intake temps - go and buy a cheapo digital multimeter that has a temp sensor wire - then slip it in the intake boot at the throttle body.
    Also listen out for knock - I'm not convinced knock sensors are working in all cars or even all conditions.
    • Paulm
      • Dec 2003
      • 489
      not sure how it will perform.
      No metal gasket, must admit i am pretty lazy. i work more reactive than proactive.
      I will monitor intake as i have a sensor and gauge made ages ago for my cossie. wont be doing egt just now as I have sold the front pipe but will get something sorted out for the front pipe hole maybe the same adaptor as you
      I will be careful with knock but my car still wont go right still the same prob low boost between 3 and 4k. I have bought a fuel presure gauge setup which I intend to fit this time home, I have also bought a new Lambda so will try that
      Paul
      S4 2.7 Twin Turbo, with a few mods
      • audiman
        • 4827
        Be careful with the headgasket thing too, will cost more to do if it goes..... sorry, when it goes. They wont take much over 300bhp. Trust me. BTDT, it made the turbo coolant pump + rad blow apart and i had to do the headgasket aswell then
        Tom C - www.rcmr.co.uk
        Audi UR Quattro
        Audi 100 C3 2.0 5 cyl 115ps
        Audi B5 RS4 645ps 911nm
        • Doug_RS2
          • 3847
          They will take more Tom - Ask Mark H !!! But be careful.
          • audiman
            • 4827
            Good point forgot about him. But trust me, its worth doing to save the extra expense.
            Audi UR Quattro
            • Paulm
              • Dec 2003
              • 489
              #21
              Is Mark still on standard gasket if so how much power is he running
              Paul
              • Doug_RS2
                • 3847
                #22
                I think he is still on the paper and over 400bhp but he seems to be lucky with that!
                • audiman
                  • 4827
                  Very lucky. Its not a good idea, it maybe that mine was weak, but its a common fact 300bhp is the paper limit
                  Audi UR Quattro
                  • Mark Halligan
                    • 2001
                    Not anymore the engine is now stripped down, however when I took the head off, the gasket was in good condition, I dont know how though, cos some high boost went through them cylinders.
                    Mark.
                    Mark - Modded
                    • Mihnea
                      • 1288
                      #25
                      Mark.
                      This paper head gasket issue is mainly a problem in 3Bs, not ABY/AAN/ADUs, and I strongly suspect that it has lots to do with the weakness of the ignition system on the 3B. I've had my mate's S4 running 352crank HP and 570 Nm of torque with 1.9 Bar on a paper head gasket, and if he hadn't melted a piston because of his fuel pump that went south, the gasket would still be a gasket today. However, when he took the engine apart, there was no damage to it.
                      I've also had several other examples of ABY/AANs running very high boost and not having a single head gasket problem...
                      Cheers all,
                      Mihnea
                      www.MRCTuning.com
                      info@MRCTuning.com
                      Workshop Directions
                      • Paulm
                        • Dec 2003
                        • 489
                        #26
                        that is very good to know, it will stay paper then
                        • audiman
                          • 4827
                          Ahhh, you never told me that before Mihnea. Consider your wrists slapped!! Damn these 3B's, i want an ABY
                          Audi UR Quattro
                          • Beetie
                            • Oct 2003
                            • 1517
                            My thoughts entirely!
                            • Mihnea
                              • 1288
                              #29
                              Just get a full wiring loom/cam cover, coil packs, ECU off of an ABY/AAN/ADU and we'll turn your car into a monschter :-D
                              As if it weren't a monschter enough now
                              www.MRCTuning.com
                              info@MRCTuning.com
                              Workshop Directions
                              • audiman
                                • 4827
                                @Mihnea, its Monster!! LOL
                                Yeah well maybe i could do a coilpack conversion If it got developed
                                Audi UR Quattro
