Horrible Pinking!!!!!!
  • audiman
    • 4827
    compression test may not show up the problem, but it does sound like a possible h/gasket failure leaking between two adjacent cylinders. Audi dealer dont supply a kit of gaskets, they are all individuals. ECP used to sell just the headgasket, but couldnt sell the correct bolts (Audi only). GSF/ECP sell the wrong bolts BTDT twice!
    Std unleaded wouldnt cause it to knock like that (well, shouldnt!), but usually headgasket failure will make it ping badly.... guess it could just be the very start of it. Try a compression test, and if that doesnt show it up it may need a cylinder leakage test doing (applies greater pressure to combustion chamber).
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
    • audiman
      • 4827
      The usual give away with manifold blows is the missing studs either end of the manifold, usually the ones you can actually see.
      Audi UR Quattro
      • rallyejames
        • Apr 2008
        • 129
        No studs missing...or bolts....noise seems to be coming from head (cam) hard to tell?
        thanks for the info Audiman....will do a compression test and let you know results.
        • spink
          • 4382
          gsf sell the 'reinz' head sets for 70 odd quid(my local engine rebuild place wanted £250!),make sure they send you one with a metal head gasket though as they sent me a paper one 1st off.
          • GT500
            • Jun 2006
            • 2181
            Try listern to how mine was:
            Linky
            Only makes a knock as the engine accelerates. Not if held at any revs..
            Rob..
            87 UR 20v ABY
            97 S6 Avant
            • rallyejames
              • Apr 2008
              • 129
              Well did a compression test last night and the results are as follows....
              Nu 1.........125 psi
              nu 2.........125 psi
              nu 3.........123 psi
              nu 4.........60 psi
              Nu 5.........60 psi
              gaskets ordered from Main dealer today,so hopfully will get cracking over the weekend.
              Thanks for the vid link GT500.....very similar noise,but not so severe i think? and the noise is coming from the back of the engine from the same place as the 2 down pots...
              Is there any particular things to look out for when replacing head gasket?
              Many thanks James
              • andyg plym
                • Nov 2006
                • 4646
                mate i reckon the main thing is to take your time, nothing will pish you off more then feeling the pressure of running out of time!
                Where in Kernow are you anyway? Im going to Helston tomorrow night
                • rallyejames
                  • Apr 2008
                  • 129
                  Won't rush it.....Helston!!!! im 10 mins away,in Longdowns between Falmouth and Helston...pop in for a brew and a look?
                  • andyg plym
                    • Nov 2006
                    • 4646
                    friday i meant......not tomorrow
                    • rallyejames
                      • Apr 2008
                      • 129
                      Your more than welcome to pop in and have a listen!!! i will be in on Friday night.
                      • GT500
                        • Jun 2006
                        • 2181
                        Many thanks James
                        I would get the seals for the water rail and change the small hose under the inlet mani for the turbo feed.
                        Leave all the exhaust mani and turbo on, its a bit of a heavy lift but saves loads of time and knuckles!
                        Rob..
                        87 UR 20v ABY
                        97 S6 Avant
                        • audiman
                          • 4827
                          Check that the head surface and block surface are 100% dead flat using a straight edge. Make sure there is NO oil/water on the surfaces or on the headgasket when you put it back together.
                          I would take exhaust manifold off and replace all nuts/studs and the gasket etc, and check manifold flange for straightness, whilst the head is off.
                          Good luck.
                          Audi UR Quattro
                          • rallyejames
                            • Apr 2008
                            • 129
                            will defo check head for skimming??? the manifold bolts don't look bad at all...look fairly recent but might replace when the head is off....will replace pipes as you said..thank you! need as much info as poss.Head bolts are not replaced according to Autodata? does that sound right to you guys?
                            • audiman
                              • 4827
                              Autodata is wrong! The MUST be replaced. Any bolt that has an angular torque and not just a Nm setting is a stretch bolt and so should be discarded after use. I have original factory manual and that says replace.
                              Audi UR Quattro
                              • rallyejames
                                • Apr 2008
                                • 129
                                So head bolts are a must then.......will get on to my local dealer tomoz....
