Piston Sample for CP
  • Billman
    • 4129
    Hi people,
    does someone has a spare or old piston he doesn't need so CP can make a scan of it?
    the adress would be:
    Performance Unlimited
    3 Chessingham Park
    Dunnington
    York
    North Yorkshire
    YO19 5SE
    England
    Tel +44 (0) 1904 489332
    Fax +44 (0) 1904 488355
    Go Holset or Go RS4
    Yes I have one somewhere - pretty sure it is not oversized. Let me check in the garage later.
    • Billman
      • 4129
      Thanks Paul, that would be nice!
      Go Holset or Go RS4
        CP already have a Piston for the S2 on file, I confirmed this with Darius
        Originally posted by Jamo
        I'm enquiring on whether you have on file the specs for the Audi 20v Turbo S2 engine code 3B / ABY or S4 engine code AAN?
        If so can you produce custom pistons for a stroker engine.
        Originally posted by Darius
        Sent: 20 June 2007 16:26
        To: Jamo
        Subject: RE: Custom Audi 20V turbo Pistons
        Hello Jamo,
        We do have that engine on file and can make stroker pistons to your specifications.
        Here’s the cost:
        Piston
        $112.00
        5
        $560.00
        Standard Wrist Pin
        $10.00
        5
        $50.00
        High Grade 9310 Pin
        $22.00
        5
        Locks
        $1.50
        10
        $15.00
        Lateral Gas Ports
        $15.75
        5
        $78.75
        CP Groove
        $3.00
        5
        Contact Reduction Groove
        $3.00
        5
        $15.00
        Pin Fit
        $5.75
        5
        $28.75
        Rings
        $21.00
        5
        $105.00
        $852.50
        The pistons come standard with double pin oilers and accumulator grooves.
        Sincerely,
        Darius Tarman
        Sport Compact Sales/Tech Support
        CP Pistons
        1902 McGaw Ave.
        Irvine, CA 92614
        USA
        Phone: 949.567.9000
        Fax: 949.567.9010
        Email: dtarman@cppistons.com
        CP Pistons Carrillo Industries, Inc., offer high quality performance products with excellent customer service. We strive to provide the best internal engine components to the customer; offering both pistons and rods.
        A member of Pankl Racing Systems
        Your contact just needs to contact Darius for the specs
        • lind4hl
          • Jul 2008
          • 2465
          How good are these pistons compared to Wiseco/ JE??
            Just as good, they run tighter clearance than JE on the manual although I've been educated all is not what it seems in the JE spec
            Albert uses them in his race S2
            • lind4hl
              • Jul 2008
              • 2465
              Awesome, cause they looked really cheap..
              yeah i think JE is many $$ about the brand..
              • AUDIS2avant
                • Jan 2009
                • 670
                • Country: Denmark
                lindahl : they can take more abuse in our cosworth engines then JE can, so i´d say they are better.
                Quality looks and feels better also
                • bsavictor
                  • 55
                  • Home: United Kingdom Current: Scotland
                  I live 20 mins away from Dunnington, would be nice to meet these people, maybe they can also supply Kawasaki 250 KXF pistons ( Moto-X bikes ), I replace my sons and his friends every 10 hours racing, so that is 27 a year... please let me know what questions you want to ask ?
                  Regards
                  Cameron
                  • Billman
                    • 4129
                    I have made a search in good with something like "cp pistons any good" and a forum with bikes came up and they said that the CPs last longer on the bike than wiseco. Dont know if its correct but do a search.
                    Go Holset or Go RS4
                    • Billman
                      • 4129
                      @paul
                      did you checked your piston out? I think its not an issue if it is an oversize one since the diameter is of no interest.
                      Go Holset or Go RS4
                      • Billman
                        • 4129
                        anyone with a piston??
                        Go Holset or Go RS4
                        • Billman
                          • 4129
                          Come on people, nobody has a piston he can give away as a sample?
                          Go Holset or Go RS4
                            Oh is this still a live request... i stopped following the thread after Jamo said they should have one on file. I will look tonight....
                            • Billman
                              • 4129
                              No it is. They say it is better if they make the scan.
                              thanks
                              Go Holset or Go RS4
