Emissions tips
  • Acidburn
    • 13459
    Emissions tips
    Just a quick question anyone got any tips on getting a car thru the emissions test, its been once and failed so new lamda sensor been put on and cat checked plus some stuff added to the fuel what the mot station recommended. New maf as well just wondering if there is anything else that could be done. This isn't my s4, its the A4 as I want a new mot before it goes up for sale and its being done by a friend so I currently don't have access to it.
    Vagcom has been checked and the codes sorted out, just want to get it thru the mot so I can get rid as I need to make space before I move
  • mcandmar
    • Apr 2004
    • 5118
    Get it as hot as possible, find an open road and do a few WOT runs though the gears. My local test center is right next to the airport which is convenient, lots of long straights to get it really hot.
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    • andy10v
      • 5996
      Check plugs?
      Sold ABY-stock
      • Acidburn
        • 13459
        Its had new plugs less than 300 miles ago plus new r/cover, ecu, coil packs
        • andy10v
          • 5996
          ok, never mind then.
          Sold ABY-stock
          • Acidburn
            • 13459
            thanks for the ideas tho, starting to get a bit fed up with the car
            • Couchie
              • Jan 2009
              • 12
              Put a cup of ethanol in your tank !
              • gavs20v
                • Sep 2004
                • 3057
                2nded on getting the cat as hot as possible
                S2 Cabriolet.........
                • dubmeister
                  • 522
                  What were your emissions readings?
                  CO, HC & Lambda
                  When was it serviced last, I know it had plugs recently, but oil & filter?
                  I have quite a lot of cars in that fail miserably and are cured by a good service!!!
                  The Cat HAS to be 'KIN HOT!!!!
                  Most Bimmers won't pass the emissions till the fan has cut in at least twice!!
