Where is the fan resistor in ABY an ADU engine bays?
  • Josh-stateside
    • 741
    I allways wondered where it's mounted? It's mounted on the frame rail in my 1993 audi 90 v6 car but it's getting and ABY swap and i'm wondering where to mount it. Anyone happen to have pictures?
    Josh
    It's underneath the front bumper / same side as the fan
    • mcandmar
      • Apr 2004
      • 5118
      You can see it on the bottom right of this pic, from memory it uses the same mounting point as the horns.
      91CQ20v - Gone to a new home
      93UR-S4 - The Magic Carpet
      94S2Bus - The Emerald Express
      • Josh-stateside
        • 741
        thanks for the photo. Makes sense now. However i think i might mount it like the diesels because it probably would work better with the stock v6 fan harness as long as it clears the radiator.
        • mcandmar
          • Apr 2004
          • 5118
          Should be fine, ABYs have the same PAS and Washer fluid reservoir as that pic. Only thing different is they have a plastic panel to fill the gap from radiator to inner fender.
