My alternator adjustment screw is not in good shape. I've seen vw 16v guys replace the alternator adjusters with rod ends and a coupling nut. I wouldn't mind doing this but i can't quite picture the details. Does one rod end need to be right hand threads and the other left hand threads? IS there anything wrong with this setup that I'm talking about? Also does the rod ends need to be sperical bearings versions? I'd say no correct? It it goes well I might consider making one for the power steering setup.
Thanks
Josh
Thanks
Josh
