poor starting
  • s2driveruk
    • 12696
    poor starting
    Anyone point me in the right direction, seems my car sort of stumbles into life rather than a crisp couple of cranks then fires.
    Changed the plugs recently and still seems to be the case on a cold start? Plugs were dry and so were lead ends and tubes when I swapped them out
    Presuming a sensor or something else which identifies rotation and firing position could be amiss.
    Thanks,
    David
    1992 3b S2 Coupe
  • max_s2
    • Mar 2006
    • 498
    • Country: Latvia
    coolant temp sensor?
    • Nace20
      • Jul 2007
      • 721
      • Country: Slovenia
      which one ? on the head or on water rail ?
      S2 limo
      • max_s2
        • Mar 2006
        • 498
        • Country: Latvia
        Could be the one on the head, or maybe MFTS. I dont know exactly witch one on a 3B is used for fuel calculations when cold/hot etc.
        • s2driveruk
          • 12696
          actually the one on the back is the one i havent replaced so could be a suspect. Also fan failed to run the other night, cant remember if that is linked to the mtfs?
          1992 3b S2 Coupe
          • max_s2
            • Mar 2006
            • 498
            • Country: Latvia
            I think thats a yes. MFTS ir also for fan.
            You can mesure resistance of coolat sensor. When engine cold (ambient aprox 20C), resistance must be between 1.5-3Kohm. If totaly out of this range - must be replaced.
            • max_s2
              • Mar 2006
              • 498
              • Country: Latvia
              Opz.. MFTS is not for fan. For fan is the one that is screwed in to the radiator. One of MFTS function is to reduce boost (turn off N75 basicly) if engine is too hot.
              • Knight Rider S4
                • 3541
                I'd give the dizzy cap a good clean(remove carbon deposits on contact points ) and make sure the rotor arm end is nice and clean , see if that helps
                93 S2 Avant Parting
                91 URQ RR
                02 A4 tdi Avant
                • popdemonic
                  • Dec 2007
                  • 1304
                  • Country: Thailand
                  IIRC if the coolant temp sensor failed.You may hook up on the CC to see what does the ECU read the on the coolant temp.
                  one of a few I5 from Asia.
                    PM me your address David, i've got a known good rad switch you can have to see if that helps with your rad fan problem
                    • s2driveruk
                      • 12696
                      Alex, you're a gent and you have mail
                      1992 3b S2 Coupe
                      • 4WheelDrifter
                        • Oct 2004
                        • 5773
                        • Country: Devon
                        Checking the resistance of the G62 would be a good start.
                        s2central.net for more info.
                        SS
                        • s2driveruk
                          • 12696
                          good call, cleaned up the contacts on G62 and she now starts crisply again, thanks guys
                          next step....bloody fan again. cleaned the contacts on the thermo plug at the base of main rad but still nothing so i'll have to drain down and pull it out and see from there. gives me the chance to put on new longer wires and the correct multiplug connector block i have too.
                          1992 3b S2 Coupe
                            G62 Coolant Temperature Sensor Info for future ref
                            If the G62 coolant temperature sender is broken, the ECU may "think" its cold out all the time, leading to higher duty cycles on the injectors and, therefore, rich runnng conditions (which, by the way, can burn out the catalytic convertors) and poor fuel economy. Part No. is 035 919 369 M (KATE calls it a thermal switch - No. 9 Illustration 919-65 (A10Q, 1993))
                            The G62 is a temperature-influenced variable resistance. The AAN ECU drives out a voltage (5? 12?) to the G62 via ECU pin T45/55 via a Grey with Brown stripe (GY/BR) wire. The return current is returned to ECU ground pin 30 (presumably via a brown wire).
                            From Bentley, the G62 (Engine Coolant Temperature (ECT)) sensor test procedure is as follows:
                            Allow the engine to cool to room temp (68F/20C)
                            Disconnect ECT sensor from harness connector
                            Switch multimeter to resistance range
                            Connect multimeter to terminals 1 and 2 of the ECT
                            Resistance must be 1500 to 3000 ohms
                            IF NO = replace ECT
                            IF YES = check wiring between sensor and ECM (ECU)
                            Reference: Bentley pg. J28-22
                            • s2driveruk
                              • 12696
                              anyone have a known good G62 I could check with, beginning to suspect this little chappy as part of the problem with saturday's performance issues
                              cheers
                              David
                              1992 3b S2 Coupe
