crankshaft timing pulley gear / wheel key sheared - any alternative parts ??
  • dave4
    • Dec 2007
    • 29
    • Home: United Kingdom Current: Spain
    Hi all,
    The key sheared on mine 200km into a trip across Spain (after a cam belt replacement) I´m back at my home garage,
    and they are having trouble getting one quickly - is there an alternative part that can be used from other Audi / vw´s ??
    I think its the one mentioned in this post here - http://www.s2forum.com/forum/showthr...ght=crankshaft
    PART NO. 034105263A ??
    any help gratefully recieved as I´m trying to get to my ferry in Bibao . . . . . . . . . .
    cheers !!
  • 220bhp
    • 2578
    If the key is broken and allowed the pulley to spin, I am afraid you will have bent the valves and a new pulley wont fix it, you will need to replace the valves ,which means taking the head of. I sincerely hope I am wrong and that it hasn't spun.
    • S-Express
      • Nov 2006
      • 1133
      Originally posted by dave4
      Hi all,
      cheers !!
      the key is a standard engineering item, normally come in 5mm/6mm/8mm widths, so readily available from most engineering/trade outlets.
      Good luck...
      • dave4
        • Dec 2007
        • 29
        cheers 4 the replies - getting new one on tuesday - hope there are some valves left
        (ARGHHHH !!)
        • jade
          • Jan 2005
          • 1811
          Key way is normally broken when fitting the pulley without locking tool, the Key way is only for locating there no strength in it. The 450nm is what holds the pulley
          RS 2 580HP
          • Rocco
            • Aug 2007
            • 6393
            • Country: Spain
            where are you now Dave?? i live "near " 200kms from Bilbao ,may i can let a hand??
            • volcano rs
              • Jun 2005
              • 2265
              Good luck...
              not on the sprocket it isn't .its one complete unit .the key is part of the sprocket unless you buy the steel one like this
                - is there an alternative part that can be used from other Audi / vw´s ?? I think its the one mentioned in this post here - http://www.s2forum.com/forum/showthr...ght=crankshaft
                PART NO. 034105263A ??cheers !!
                That is the correct PN. It is common to Audi I5's all the way back to 1982.
                You will also need a new crank bolt, PN N 010 143 2
                • dave4
                  • Dec 2007
                  • 29
                  Cheers Rocco but I had to get a Grua (breakdown) to bring me base (nr Estepona)
                  Mechanic is fixing work under guarantee, but parts always take a while here in Spain so thats ******ed my holiday . . . . . . . .
                  thanks for all the other posts as well guys!
                  Seriously thinking of selling the thing at the moment - anyone in interested in LHD S2 thats had LOTS of work done !!
                  (Arghhhhhhh) (Again)
