Fuel pump good for some 350 chp ?
  • OrMar
    • May 2007
    • 132
    • Country: Croatia
    Rated at 100l/h @ 6.5 bar
    Could it support my 3b RS2 conversion ?
    Thank you,
    Mario
    Approx 120l/h at 1.3bar boost (5.3bar fuel pressure) is 350bhp territory
    You really need the flow graph for this pump, but if its rated at 100l/h at 6.5bar then you should be OK - is this pump from factory AAN ?
    If so then it should hold up fine... Going to RS2 fuel pump gives a bit more headroom... Going to Bosch 044 provides even more.
    • terrybullwon
      • Mar 2006
      • 8782
      I have one here that is 165lph @5 bar that is a bosch motor sport pump. I have two or three for sale.
      Chef
        Proper big boys pump there sir
        • OrMar
          • May 2007
          • 132
          • Country: Croatia
          Not sure. Bought it on ebay as "RS2 pump".
          Mario
          • OrMar
            • May 2007
            • 132
            • Country: Croatia
            I will probably go for this one if you guys convince me mine is not enough.
            Mario
              What is part number on your pump ?
              • rs200
                • May 2009
                • 1398
                • Home: Croatia
                895 906 091 f AAN
                895 906 091 B AAN
                895 906 089 E ADU
                this is what I find... number of fuel pumps..
                • OrMar
                  • May 2007
                  • 132
                  • Country: Croatia
                  It's a Pierburg pump with following numbers on it:
                  94T283
                  7.21651.00
                  895906091B
                  Mario
                  • OrMar
                    • May 2007
                    • 132
                    • Country: Croatia
                    OK, so mine is obviously AAN.
                    Mario
                    • rs200
                      • May 2009
                      • 1398
                      • Home: Croatia
                      for this number 895906091B -stop to selling in audi servis 31.1.1996,and they gives a other part 985 906 089D
                      it is not posible to be from aan or adu because they have to selling the parts for minimum 10 years.
                      • rs200
                        • May 2009
                        • 1398
                        • Home: Croatia
                        895 906 091 B it is a older version of rs2 fuel pump, they are 100% same pumps.
                          Originally posted by rs200
                          895 906 091 f AAN
                          895 906 091 B AAN
                          895 906 089 E ADU
                          This may not be helpful but the AAN 43 mm diameter fuel pump PN is 8A0 906 091G. This is the PN in ETKA (I am told). However, Pierberg may have another PN. My OE AAN FP was VDO which has 8A0 906 091G etched into it.
                          I am currently running an 091G equivalent Bosch 43 mm now. Its Bosch PN is 0 580 314 068.
                          Here is an example AAN fuel pump replacement procedure:
                          http://forums.audiworld.com/showthre...&highlight=091
                          My AAN is RS2's with MRC software (dyno'd at around 350 chp, 288 whp). I think I could use more fuel pump or bigger fuel lines (getting some pinking at WOT). The next step up is a 60 mm Bosch 005 or 044 but I am concerned about the noise.
                          Another alternative is to relay your fuel pump to increase voltage, as shown here for a C4 S4:
                          http://forums.audiworld.com/showthread.php?p=18754922
                          Or if you like to live dangerously, you can try a Walbro 255Lph GSS341 FP/
                          If you're on a tight budget and need to replace your fuel pump, the Walbro 255 is a $100ish option and can be considered an "upgrade" from stock. The numbers put this pump in between the Bosch 005 and 044 units. However let it be known that many have reported Walbro issues re: lifespan and quality wise. YMMV
                          A procedure for such a Walbro installation WAS at:
                          http://www.justfourrings.com/phpBB2/...pic.php?t=1022 (It didn't open for me just now)
                          HTH
