URS4 tapping noise ??
    I posted the link to your video on the UrS forum of quattroworld. I thought it sounded like a playing card in bicycle spokes, i.e. something rotary hitting something. One UrS4 owner said: "Sounds external, fan clutch, PS pump, or a zip tie hitting the fan." Another made the excellent suggestion of temporarily disconnecting the serpentine accessory drive belt (take the tension out of the belt tensioner) to see if it something like the fan or power steering pump etc. (If it is them, the noise will go away with the serpentine belt not driving them)
    Good luck.
      Originally posted by quattrostyle
      that doesn't sound good, at least it doesn't sound like noisy hydraulic lifters
      I've got people on the UrS quattroworld forum listening to the video and at least one person thinks it is a dead lifter (another, broken valve spring):
      • K7ERG
        • 1711
        Bit noisy for a lifter. Could be valve spring and have also heard of spark plugs going slack. I think more like a big end. Mine sounded like that but replace all the lifters and head first.
        F5 DPOR plugs are great plugs. Used them for over 10 years and never had a problem. And some covered 30000miles of hard driving with 2bar boost.
        Audi A6 AEL 5cyl Quattro breaking.
        Audi A5 3.0tdi Quattro Stage 2
        07947385043
        • baltiboyS2
          • 965
          Rip that cover off take a look around that sounds internal don't take any chances on running for long periods
          cheers Raj
          • rs200
            • May 2009
            • 1398
            • Home: Croatia
            #20
            you didnt open the coil cover yet?????
            if that hapends to my car i will open and take a look, just try to pres every lifter -and you will see which is diferent than the others... 3 minute of job....
            • asw75r
              • Sep 2008
              • 25
              Thankyou for all your help
              the cover has been removed and everything seems fine ? if i turn the engine over with no cover/coils on the tapping is not there but a very faint grinding noise from 2nd cylinder from the back on each stroke (cannot hear it on video though) sounds like metal on metal
              I`m swaying towards bent valve from valve bounce but alittle too busy to strip it to check it at the moment
              i will keep you informed and again thanks for your help
              Scott
              • RoadKill
                • Dec 2004
                • 567
                could be valve guide my dads cab sounded like that , drop the oil out see if you have shiney bits in it , if you do valve guide
                service tec @ East Kent Audi
                S2 ABY
                B8.5 A4
                • popdemonic
                  • Dec 2007
                  • 1304
                  • Country: Thailand
                  #23
                  Laters F5DPOR is !@#K up,Craig.2 of my F5DPORs gone within 2 months!!!.Definitely,
                  I got it from the Audi Dealer with 4rings logos on the spark plugs the white
                  ceramic shield was coming off cause the sound like a lifters died.
                  one of a few I5 from Asia.
                  • rs200
                    • May 2009
                    • 1398
                    • Home: Croatia
                    #24
                    I'm sorry for a open this old tread, but now i have a same problem.
                    after rebuilding the engine and have this bad noice from it. just like on the video. I put a new valve guide,new INA tappets,every baring is new, everything in engine is new.
                    but after a few minutes or running it's start this f...in noice, few days I thy to find out what it is but I can't...
                    engine runs good, oil pressure is good, no liking problem, timing belt is good (check few times),cams are in good place.
                    it starts little bit strange ,but than run perfect.
                    I put inside a ARAL 5W-40 syntetic oil
                    engine is 3B.
                    please help, help,help,help,
                    • rs200
                      • May 2009
                      • 1398
                      • Home: Croatia
                      #25
                      did this guy fix his problem ? somebody know?
