hey there folks,
I have the ABY engine and just wanted to ask...I've read the definitive guide to sparks, i'm not asking which plugs i need...but i'm desperate to change the spark plugs,
i've managed to remove the top cover/ignition coil carrier... with the allen key bolts... now i'm having trouble removing it off as the accelerator/bar/thingy at the end seems to block it...it looks like its held with a star key..is it necessary to remove this...to remove the lid?
if i do this... then how does this help me remove the sparks, which seem to be jammed under a fuel rail/black bar... anyone wanna walk me through this b4 i start and end up wrecking the whole thing?
i'm not usually a complete buffoon with these things..but it looks more complicated than normal... and i would rather have the knowledge there first b4 i attempt it...
cheers guys!
J
cheers guys!
J
