N75 Testing Article
You might find this article interesting:
http://forums.audiworld.com/showthread.php?p=18772235
The "K" is the ABY and ADU (RS2) version, the "H" is the AAN and I *think* the 3B version is the "J". Similar but different. I am running a "K" on my MRC S/W RS2'd AAN. Not totally happy with it, might go back to the "H". (Also running a 1.9 Bar 034 wastegate spring so that could be part of the equation).
N75 Question!
I think the H part number is for the URS4/S6, the only difference is the location of the electrical plug. Be very careful fitting them, i broke my last one pushing a hose onto it, was an expensive mistake
The attached PDF will educate and demystify things...Attached FilesLeave a comment:
N75 Question!
Hi all, ordered a replacement 034906283H for my avant as it has a 034906283K on it
Thing is the three branches are at 90 degrees to the connector on the H but not on the K! Do I just keep the longer of the three branches to the same (maf) hose or is there something amiss? The connector will then point forward towards the headlight rather than away from the block, any good!
Cheers for any feedback
Tags: None
