So what fixed the smoke for you?
  • Cymru1
    • Sep 2008
    • 436
    There have been many, many posts about “smoking” S2’s when there hot and in traffic (I know iv’e posted a few myself) however did anyone who had the problem actually solve it?
    I realise there may be many causes of this problem (rings, v-seals, turbo, de-cat, oil, general wear, etc) but surely someone out there must have found a fix for their particular issue?
    So what fixed the smoke for you?:-
    1) Valve Seals
    2) PCV System
    3) Head Gasket
    4) Turbo Wear
    5) Re-install Cat
    6) Oil Quality
    7) Rebuild (head/rebore/etc)
    8) Other
    Anyone?
    25
    PCV System
    24.00%
    6
    Valve Seals
    16.00%
    4
    Turbo Overhaul/Replacement
    28.00%
    7
    Better Oil
    16.00%
    4
    Re-install The "Cat"
    0.00%
    0
    Piston Rings
    0.00%
    0
    Full Rebuild (head/bore)
    8.00%
    2
    Other
    8.00%
    2
  • Tonks4x4
    • Nov 2005
    • 3062
    the only 2 issues i have had and cured are 1. Using synthetic oil, I find it to thin and causes smoke. 2. I used an exhaust off another vehicle which had running problems and had soaked the boxes in oil and fuel. Once burnt out it was all fine.
    Audi Nut!!!
    • Key Walshe
      • Feb 2007
      • 422
      Mine went from blowing our water due to a head gasket failure, straight into blowing out oily smoke. This only happened when cold and after being stood for 3hrs or more. Turned out to be the turbo, a rebuild by AET in Wakefield had it sorted. The oil seals had begin to perish meaning was building up in there when not in use.
      It's also found an extra 0.1 bar of boost (1.6 now) since its recon, which is a nice bonus...
      Audi 80 S2 Nothelle N300 Avant, 1993, Amethyst Pearl VW/Audi Car Magazine article about this very car
      Audi A6 Avant 2.5 TDi, 1995, Arctic Silver (now sold)
      BMW E36 325i Coupe, 1993, Diamond Black (now sold)
      VW Polo 1.0L 6N, 1998, Red (the missus' car)
      Aprilia Rs250 motorbike, 1998, Black (the weekend toy)
      • driftin jo
        • Sep 2007
        • 2222
        Blocked PCV system, burnt lots of oil then virtually none after fixing it
        • pixsaudisex2
          • Sep 2004
          • 3110
          but i even changed the turbo thinking it was that..
            Mine smokes and i've got 5w 40 fully synthetic in it - might try a decent quality 15w 40 semi synth and see if it makes any difference
            • popdemonic
              • Dec 2007
              • 1304
              • Country: Thailand
              8 on K24s and finally got 2871 on the car.smoke is killed.
              one of a few I5 from Asia.
              • nip
                • Apr 2006
                • 1786
                • Home: United Kingdom Current: Abu Dhabi
                mine smokes between 30 to 60 seconds after start up, easy cure i should have done this first, i never started it again = no smoke
                • Cymru1
                  • Sep 2008
                  • 436
                  lol! Never thought of that fix.
                  • nemilosu
                    • Nov 2008
                    • 196
                    • Country: Romania
                    My belt has jumped because of the belt of accessories.
                    result = 8 intake valves bent.
                    after I rebuilt the engine started from 2000 rpm to give the smoke.
                    may be the fault of the PCV system?
                    before the turbo was ok.
                    • lind4hl
                      • Jul 2008
                      • 2465
                      Trasched the valve seals maybe? just a thought...
                      • Costash
                        • 878
                        • Home: Romania Current: United Kingdom
                        Any pictures with this oil valve seals?And any hints about the make?THX!
                        • lind4hl
                          • Jul 2008
                          • 2465
                          the valve seals i mean are those that the shaft of the valve goes thru up to the lifter, spring etc.. it is golden in the color..
                          someone maybe could help me explain??
                          • Costash
                            • 878
                            Some pictures is gonna help alot!!
                            • max_s2
                              • Mar 2006
                              • 498
                              • Country: Latvia
                              Check also these:
                              Edit: I guess its called "valve guide":
