Hi all my car has developed an annoying problem . It will boost upto about 10 minutes after starting it from cold but when everythin is warmed up the turbo does not want to know ?? I hope someone can tell me what it is . Thanks rich .
boost problems
could be the MFTS or the knock sensors, what happens if you turn the car off and then back on does it boost again? also have you checked the fault codes after the boost has stopped with out turning off the engine?91 S2 coupé - RIP
98 S8 - Luxury barge -
MFTS is multi function temperature sensor. Its located on the water manifold and is the bigger of the two sensors, It has a 4 pin plug. its worth unplugging it, checking all the wiring and if its intact replacing the sensor. If its miss reading then once the car is up to temperature it could be telling the ECU to stop boost. You should still be getting .4 bar though.
If the car boosts again once its switched off for a few seconds and then back on it could be the knock sensors which are also located on the right side of the engine under the water manifold on the main engine block.91 S2 coupé - RIP
98 S8 - Luxury bargeComment
Ok thanks alot . Well went out last night and it resets itself everytime i switch the ignition off . Have full boost for 10-15 seconds then nothing again . Switch the engine off then back on and all is well for 15 seconds again . Very annoying sounds like knock sensors then ??sigpicComment
