Does this hose pop off any one elses S2?
  • terrybullwon
    • Mar 2006
    • 8782
    The metal intake pipe that runs across the cam cover?
    With samco's i found this very tight, now on two cars. One was even worse as it had new engine mounts.
    Cheers James
    Chef
  • stevieyid
    • Apr 2005
    • 2251
    Cheers James
    I wonder who's that could be
    • Rusty
      • 18953
      Which hose, IC to X pipe or X pipe to TB? Had issues with both over the years, need to take your time when tightening the clamps to make sure that they're sitting right and are tight, as tight as you can get on a screwdrive handle with jubilees, I've found Mikalors pop off, must be due to less pressure with the larger band.
      • terrybullwon
        • Mar 2006
        • 8782
        Well spot on Sir!
        Its very tight indeed. And the intercooler to the pipe that runs across the cam case is subject to the engine moving
        I took Steve's pipe and extended it by over 30mm and now the clamping surface area has been increased it works 120% better
        Chef
        • Rusty
          • 18953
          The ABY pipe is better as it is longer and so flexes more with the engine.
          • terrybullwon
            • Mar 2006
            • 8782
            This was done on a ABY The samco had only about 10-15mm grip on the pipe cold and about 4mm more when hot. Even If i adjusted both ends time and time again.
            Chef
            • Rusty
              • 18953
              Picture was a 3B, your car Terry if I'm not mistaken.
              You have to fit the X pipe end first, get the pipe sitting on the X pipe flange, it doesn't sit square unless you get it just tight enough to hold and then manipulate the pipe. Then get the hose sitting nicely on the X member and repeat
              • terrybullwon
                • Mar 2006
                • 8782
                Well this one did not fit properly at all but,
                now fits as i would say "it should do at both ends" . Why mess about all day when something is done right it only has to be done once and left alone just my two pence hey...
                Pictures later
                Chef
                • lind4hl
                  • Jul 2008
                  • 2465
                  James, what have we learnt!!!
                  Wiggins, wiggins!!
                  • Knight Rider S4
                    • 3541
                    I have fun with this to...first place I check when it comes to any leak testing ...
                    93 S2 Avant Parting
                    91 URQ RR
                    02 A4 tdi Avant
                    • terrybullwon
                      • Mar 2006
                      • 8782
                      Well i have a hose with an extension already on if any one would like it PM me. It must be a comman problem. Worse if you have done your engine mounts so it sits higher for sure.
                      @wiggins LMAO!
                      Chef
                      • stevieyid
                        • Apr 2005
                        • 2251
                        my car has 034 engine mounts that ant said raised the engine a little hence the reason why the roose hose was a very tight fit. James has sorted it for me though
                        • prosty
                          • Jun 2005
                          • 1114
                          Get an AAN TB they have longer neck so you can have a wider hose clamp , I have like 8 TB's in my garage hehe
                          2004 9-5 aero
                          2009 Subaru Legacy Diesel
                          1994 Toyota Supra Eurospec 6-spd LHD
                          3-4 Audis in parts
                          • moradi2k
                            • Jan 2009
                            • 19
                            • Country: Norway
                            i like T-bolt clamps when normal clamps don't do
                            • prosty
                              • Jun 2005
                              • 1114
                              Yes those are powerful but with the 3b and aby spec TB they won't do the trick since the neck of the tb is too narrow.
                              It could work but it will go over the edge of the tb neck so you might damage to tb rubber / silicone
                              2004 9-5 aero
                              3-4 Audis in parts
