Bosch 044 Fuel pump Coupe, Parts needed
Yes i know, i didnt have one on my pump.
I have orderd banjo + domed nut, it will arive tomorrow.sigpic
Audi S2 Coupe - 92
Koni + H&R. PowerFlex bushes. 3" Exhaust
RS2 IC. RS2 TURBO. RS2 EX MAINFOLD
Best ET 2006 13.8 @ 157 Km/h (Stock turbo and EX mainfold)
Best ET 2007 12.78 402m, 0-62mph: 4.2 sec, Speed: 175 km/h (GTEC)(1.1bar)
Best ET 2007 201m 8.15@140km/h
Best ET 2008 402m 12.34@177km/h
My Project
http://www.s2forum.com/forum/showthread.php?t=16997Comment
Got me wondering if I have the one way valve on my setup... I have the 044 pump built up in a new cradle ready to fit.Paul Nugent
the fitting i bought comes with the 044 standard.
Spare part list from bosch see the attached file.Attached Filessigpic
Audi S2 Coupe - 92
My Project
So item '800' is the non return valve ?
If so then yes I think its there on mine.Paul Nugent
No the 800 is a black cover in shiny rubber when shipping. same on the bottomis a plastic plug.sigpic
Audi S2 Coupe - 92
My Project
Today i recieved some parts, and hit a snag.
I have 1992, with 3B engine. i have read that my strainer should fit the new pump basket and the pump should be 60mm.
The strange thing is that the strainer and the basket is the same pice and i have the thin ABY pump ?
i will order the damn strainer tomorrow,
Parts
Audi S2 Coupe - 92
My Project
i have just done this o44 mod look at my tread and post parts i used, mine ia an ABY
only thing i did different to the pic of pump thats built up is i took out the spacer (nut looking thing on the bottom in the thing that looks like a one way valve, i have been running on the new 044 pump now for a week and works great.
But doesent the pump sit lower ? looks on the picture that you just put it in the basket and skimmed of a bit on the went hole ????
What do i modiy to get the pump to sit as low as needed ?sigpic
Audi S2 Coupe - 92
My Project
yes that all i did, i compared to the old one i took out and they were sitting the same at the bottom, if you make it to low it wont flow as well, i run the car so low on fuel other day needle didnt move up and still run so i would not worrie about it as most people wont run that low on fuel, have you seen bottom of your tank yet? the pump sits in a dish bit so will alway have a small amount of fuel even when needle says no fuel.Comment
okey, could you remove the old strainer from the old pump ? or how did you manage to compare ?sigpic
Audi S2 Coupe - 92
My Project
hm.... i dont have 3 groves on teh pump ??, onlu a grove all way arround.. or do you mean if you make 3 cuts it will flex out and the pump will sit lower ?sigpic
Audi S2 Coupe - 92
My Project
