Lightened Flywheel pictures
  • Billman
    • 4129
    Can we maybe make a collection of lightened 7A, 3B ect flywheels so we can see the possible ways of doing it? The one is this one (but i have seen other ways i.e. with holes).
    cheers
    Go Holset or Go RS4
  • Billman
    • 4129
    Thanks for the replies :-p
    here are some more pictures.
    I also read in a german forum that the stock FW are not zero balanced on purpous and because of this one can lighten the stock 3B or 7A FW on a lathe without having to have it balanced when the material is removed from the back side like in some of the pisctures i am going to post.
    What do you think?
    Go Holset or Go RS4
    • quattrostyle
      • Oct 2006
      • 6229
      I like the one that's skimmed on the backside best.
      • Bram
        • Aug 2006
        • 2582
        This is my lightened 7A flywheel at 7 kg
        • Bram
          • Aug 2006
          • 2582
          These pics come from someone else who I forgot it was
          • Billman
            • 4129
            How thick is the material left there? Did you balanced it then?
            They said that it should not be less thick than 7-8mm.
            Go Holset or Go RS4
            • Bram
              • Aug 2006
              • 2582
              You should ask Aelred about this thickness because he did the machine work on it, but from what I have seen and got as feedback from Aelred my lightened 7A flywheel was balanced to 0
              • terrybullwon
                • Mar 2006
                • 8782
                I got mine to just over 6KG
                Then the fly wheel was refaced and balanced
                Chef
                • 20Vcqdriver
                  • 829
                  So how much does a standard 3B weigh and any detrimental effects taking it to 7Kg other than more vibration at idle?
                  1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
                  2004 A4 2.5TDi convertible, re-mapped to 180bhp
                  2011 A5 sportback 3TDi-Backbox delete, remap
                  • trackslag
                    Account Disabled
                    • Sep 2009
                    • 171
                    who do you guys get to lighten these fly wheels? and costs. any help would be great
                    • Flat on my back
                      • Jan 2007
                      • 2449
                      Basset Down Balancing probably...
                      Carlos.
                        Go via Aelred
                        • SteveH
                          • 4460
                          Basset down undertake the balancing, but not the machine work. South Cerney are good, but on the expensive side
                          Highly recommended http://www.vintagecarrestorations.com/scemain1.htm
                          91 Modded 3B
                          14 A6 Avant Black Edition
