not sure. i got a coilpack type thing now. when i hit 1.4 bar it sounds and feels like its a stammer. wind off to 1.2bar and its fine. damn old crap. these are about 3x better than the subaru ones though but they mnever have output stage problems.
is this not a fuel/boost type cut thing. expect paul may be able to help. not sure how motronic judges boost and whether it has a boostover rpm table not to be exceeded.
My guess is you have a dieing/weak coil. You need to check your coils for relative strength and probably replace the weakest one(s). Have a look at this, it will help you figure out which is the bad coil:
