S2 new issue :(
  • Cobra
    • Apr 2009
    • 78
    • Country: Portugal
    S2 new issue :(
    In the last few days, I'm getting a bit disapointed with my S2...
    Got it serviced and homefried, and everything was starting to look good, but...
    When I'm driving normally with a soft driving style everything is ok, but as soon as I floor it a little bit more violently as it goes by 3000rpm it stops going, no wooooooompf, no lights light up on the dash, no other problem but it stops to accelerate
    Any ideas!?
    -Fuel pump??
    -Injectors??
    -Boost leaks??
    -Turbo??
    *95' Clio Williams
    *94' 19 16valve
    *94' S2 Avant
  • dest
    • 4287
    Sounds like you have got a boost leak
    • Cobra
      • Apr 2009
      • 78
      • Country: Portugal
      I thought so...
      Sent an email to Roosemotorsport for the Boost Kit, hope it solves the problem...
      If it doesn't its back to the drawing board
      I know you have this boost hose kit... Does it come ready to use, with all the clips, and everything?
      *95' Clio Williams
      *94' 19 16valve
      *94' S2 Avant
      • quattrostyle
        • Oct 2006
        • 6229
        no, hoses only. Maybe someone has the dimensions of all the boost clamps needed so you can purchase them and fit them at the same time as the hoses.
          An AndyP boost leak test kit might help you here, have a search for it
          • Cobra
            • Apr 2009
            • 78
            • Country: Portugal
            Just sent a Pm to Andy, thanks for the tip...
            But I guess it wont do any arm to change the hoses
            And I thought that for the price, the kit came ready to use
            *95' Clio Williams
            *94' 19 16valve
            *94' S2 Avant
              Upgraded boost is often the killer of tired old hoses.
              • dest
                • 4287
                Try unplugging the maf a few times, that can cure it too. First thing to try, quick and free too!
                • Cobra
                  • Apr 2009
                  • 78
                  • Country: Portugal
                  Yeah, should've adressed the hoses before the HF...
                  Gotta search the clamps or if one or two got killed by the boost
                  I tried it, but it must be a hose...
                  Which ones are most prone to "suicide"!?
                  *95' Clio Williams
                  *94' 19 16valve
                  *94' S2 Avant
                  • Andreas
                    • Nov 2005
                    • 731
                    which aren't? <:
                    Andreas Lundstroem
                    A4 STCC Avant -04
                    Audi /S/2/ Sedan -94
                    prev.
                    Audi /S/2/ Coupe -91
                    • Cobra
                      • Apr 2009
                      • 78
                      • Country: Portugal
                      Originally posted by Andreas
                      which aren't? <:
                      I'm new to these cars...
                      Thought that maybe there could be one, that was the weakest link...
                      *95' Clio Williams
                      *94' 19 16valve
                      *94' S2 Avant
                      • Andreas
                        • Nov 2005
                        • 731
                        For me the weakest link/hose is the one that sits between the throttle body and the pipe that runs along side the engine towards the intercooler..
                        But I've upgraded all the hoses as I've gone along.. but that one went first!
                        EDIT: by getting a boost hose kit from roosemotorsport you are a lot smarter about this than I was btw <; I've bought one hose at a time = fukkin expensive <;
                        Andreas Lundstroem
                        A4 STCC Avant -04
                        prev.
                        • david
                          • Oct 2008
                          • 1268
                          [SIGPIC][SIGPIC]/SIGPIC]92 3B pearl white=gone back home to Germany,probably in bits and pieces
                          RS2 VOLCANO BLACK] soon to be broken to bits
                          • Cobra
                            • Apr 2009
                            • 78
                            • Country: Portugal
                            Originally posted by david
                            Ok, disconnected the maf a few more times, and even disconnected the battery (i don't think I ever did it, since I got a hold of Paul HF loaner)...
                            And voila a miracle happens and the HFS2 lives again on all its glory
                            But the scare led me to buy the roose motorsport hose kit, it wont do any arm, but the tyres for the new 17'' will have to wait... The HR spring kit will get home next week, lets wait and see if it comes together alright
                            Thanks again you guys for your pointers
                            *95' Clio Williams
                            *94' 19 16valve
                            *94' S2 Avant
                            • popdemonic
                              • Dec 2007
                              • 1304
                              • Country: Thailand
                              good idea to hook up your TPS though,BTDT.
                              noticed any sound of leaks under boost?i assumed
                              if the car won't going under boost it's sound like the
                              leak should be big enough to hear the sound.
                              one of a few I5 from Asia.
