Injector seals
  • gunman
    • Jan 2009
    • 660
    Injector seals
    Just wondering are the injector seals handy enough to get the S2 (AYB)? I noticed a slight whiff of petrol today with the windows down, first I thought a pipe underneath was leaking but it tuens out number 1 injector is a bit damp at the top. I take it these are bosch injectors and fairly standard seals?
    cheers
    1996 Audi S6 Avant.
    1994 80 TDI - Daily Driver
  • Kieron20V
    • Mar 2008
    • 1505
    Part number is 035906149a, should be pretty easy to get hold of, either through your audi dealer or a bosch agent.
    1994 URS4 Avant RS2+
    • s2_bo
      • Oct 2005
      • 6067
      Dealers can supply them at about £2+vat each. I have a new set of 10 if you want it.
      91 S2 coupé - RIP
      98 S8 - Luxury barge
      • gunman
        • Jan 2009
        • 660
        Cheers Guys, S2_bo, I've dropped you a PM.
        1996 Audi S6 Avant.
        • gunman
          • Jan 2009
          • 660
          Leak got worse so I had to do a temp fix tonight, I had some injectors out of a cavalier sri 130 engine (also bosch) so I used a couple of the seals off them for now. They are the same size but not a thick if you know what I mean (Girth). Seem to be sealing OK anyway.
          Thanks to S2_bo I should have a new set in next week anyway.
          1996 Audi S6 Avant.
          • S-Express
            • Nov 2006
            • 1133
            i did a group buy on these a couple of years back - even got viton ones (better than rubber) - I think they worked out at 10 p each. (they're a standard O ring size).
