Doing the timing belt on the 3B this weekend. How do I remove the roller?
Any tips/instructions on pulling the T-belt roller from the block?
Ben
Calgary, Alberta
Canada
1991 CQ e//S2 w/ RS2 spec 3B 20vt
Panther Black Metallic
www.moda-architecture.caTags: None -
You have seen these, right?:
and an AAN timing belt R&R DIY (Fred Munro, Sudbury, Ont., Canada):
http://s-cars.org/postnuke/downloads...Belt%20R&R.pdf
I know there is an RS2 timing belt R&R on here somewhere. Here is a bit more info:
Whatever you do, do NOT use an impact wrench to remove or tighten the crankbolt. If you do, you are seriously risking breaking the crank timing belt pulley key (cast as part of the pulley).RS2'd 93 UrS4 5 spd sedan
94 UrS4 V8 6 spd manual avant -
Thanks for the links Dave. I've done the Timing belt job a few times (on various I5's) but haven't ever replaced the roller. Looks pretty straight forward.Ben
Calgary, Alberta
Canada
www.moda-architecture.caComment
