Help with timing belt change.
  • YELL MAN
    • Dec 2005
    • 537
    • Country: Shetland Islands
    Due to my coolant pump deciding it wants to start dumping my newly purchased 12++ all over the road I have decided to tackle the timing belt as it is coming up for renewal anyway.
    Could anyone tell me where the best place is to buy a crank locking tool VAG 3256? Dealers?
    Also while looking for part numbers I have come across two slightly different ones for the coolant pump 054 121 004 AV and 054 121 004AX could someone confirm what one is correct?
    Oh and this is for a ABY without aircon.
    Cheers,
    Brian
    1994 Indigo Blue S2 coupe
    1994 80 Avant 1.9 TDI
    2005 Yamaha Fazer 1000
    1953 AJS Model 18S
    The 'X' denotes that its an exchange part.
    • YELL MAN
      • Dec 2005
      • 537
      Ah ok that makes sense. Thanks for that.
      1953 AJS Model 18S
      • adamw
        • Dec 2005
        • 348
        Hi brian i can give you a timing belt? It was a new timing belt i put on the rs2, then took it off the next day when i found out it was the wrong one! So its like new.
        Also i borowed the home made crank tool from the tingwall garage... If you phone up keith he might make one for a small fee?
        cheeRS adam
        RS2+
        • Jenks
          • 261
          Without sounding like I'm on a drunken rant about whats wrong with our country I'd just like to say 'That's how the we all should be!'
          • T2Andy
            • 1903
            Your pissed mate
            • Jenks
              • 261
              Why? Is my spelling particularly poor this windy morning?
              • adamw
                • Dec 2005
                • 348
                Was it somthing i said?
                cheeRS adam
                RS2+
                • YELL MAN
                  • Dec 2005
                  • 537
                  Ah that would be great. Is it definatly the one for the ABY (054 109 119H)? I will try phoning Keith the morn if I mind. Cheers for the advice.
                  1953 AJS Model 18S
                  • adamw
                    • Dec 2005
                    • 348
                    yip definatly the one for the ABY (151 tooth).
                    i got the wrong one from burgess when i did my timing belt
                    cheeRS adam
                    RS2+
                    • YELL MAN
                      • Dec 2005
                      • 537
                      Cool. I will give you a bell sometime through the week to see about getting it.
                      Cheers.
                      1953 AJS Model 18S
                      • adamw
                        • Dec 2005
                        • 348
                        Do you have my new mobile number?
                        cheeRS adam
                        RS2+
