Difference Between Rs2 Ecu And Aby Ecu
  • superior
    • Jul 2008
    • 88
    HI All
    does anybody know the difference between rs2 ecu and aby ecu , as i have a ecu problem , basically my new chipset does not work properly{missfire holding back} in my avant aby , but when we put my chips in my mates rs2 ecu and put that in my car it works a treat .
    any info greatfully received.
  • terrybullwon
    • Mar 2006
    • 8782
    Originally posted by superior
    HI All
    What chips are they?
    I am not far from you where are you in Sailsbury?
    Chef
    • AUDIS2avant
      • Jan 2009
      • 670
      • Country: Denmark
      Sounds like there is an mapsensor Fault there(setup in the chip)
      • superior
        • Jul 2008
        • 88
        i am now in verwood just by ringwood
        • superior
          • Jul 2008
          • 88
          i fitted a new map sensor and one from my mates rs2 no joy
          • terrybullwon
            • Mar 2006
            • 8782
            Lymington
            I can try and help in any way i can
            Chef
              They are slightly different like rs2 has no temperature compensation, map sensor is also larger in RS2 by default.
              I don't think the chipsets are compatible between the two, s2central.net is the man to ask
              • superior
                • Jul 2008
                • 88
                cheers terry i will keep you informed does anyone know of a rs2 ecu for sale and no i am not jokeing or can i change my ecu to suit.
                  Whats your car spec? maybe you can get an K24 or RS2 homefry chip from s2central
                  Or just go to MRC and get your car mapped. Probably cost near enough the same as an RS2 ecu!
                  • terrybullwon
                    • Mar 2006
                    • 8782
                    A ABY with a K24 turbo and standard injectors will need a ABY or ANN ecu to run. Rs2 Or ADU runs different settings and parameters.
                    Chef
                    • driftin jo
                      • Sep 2007
                      • 2222
                      it can be changed , you need to speak to paul, S2central.net, he will be able to help you with it.
