ABY Inlet Manifold choice? - Pros & Cons?
  • LYT4X
    • Jul 2008
    • 177
    Hi Folks!
    I'm looking at changing the IM on my ABY engined ur quattro rally car project but can't decide what's the best way to go. The AAN manifold seems to make logical sense for intercooler plumbing and I know this has been done by many on here. Is there any definitive advice on what's the best route to take? What are the pros and cons of sticking with the ABY manifold or going with the AAN? Thanks in advance.
    John
    A Small Collection...
    shorter pipework, less lag and boost pressure holds better, what cons?
    • Ruffiano
      • Sep 2007
      • 1458
      Fitment is the only real "Con" I can think of. Impossible to use it with the radiator in it's stock location.
      • Acidburn
        • 13459
        unless you go custom smaller height rad ala jogi730/chris
          True, the rad can be moved so it's at an angle, there's a few pics of it done
          • LYT4X
            • Jul 2008
            • 177
            So, is AAN the way to go, or is there an even better route given a blank sheet. What bits do I need other than just the manifold?
            And is anybody selling these???
            John
              Blanket route buy the Wagner Inlet manifold so your rad stays in stock position or buy one from Pro-mo
              • LYT4X
                • Jul 2008
                • 177
                buy one from Pro-mo
                Pro-mo???
                Company or person? 'Scuse the ignorrance............
                John
                • jogi730
                  • 2335
                  Pro-Mo is one of the forum sponsors, known on here as repo.
                  Good luck whichever IM you choose.
                  Chris
                  Audi 90 quattro (Typ 85)
                  20v turbo conversion
