Need helt. Dry sump oil pan
  • Audi imsa racing
    • May 2007
    • 421
    • Country: Norway
    I am going to start building my oil pan for the dry sump system, and need some help.
    My engine lays in a hundred bits, and I need to know how thin the oil pan can be, and still having the crankshaft to go clear of the oil pan. Anybody?
    If in doubt, Flat out.
  • quattro84
    • Mar 2006
    • 947
    Two fingers high
    Do you use a stroker block? With a stroker & 6 speed subframe it is about 35mm's.
    • Audi imsa racing
      • May 2007
      • 421
      • Country: Norway
      Originally posted by quattro84
      Two fingers high
      Thanks.
      No stroking her My guess was about 40mm so I was not so far away..
      Now I can start making the oil pan.
