Best Boost Gauge for S2
  • gunman
    • Jan 2009
    • 660
    This has probably been covered many times on here but I can't find it. Can anyone recommend a decent boost gauge for the S2 both in terms of accuracy and blending in with the existing gauges\dash of the S2?
    Theres a load of cheapo's on ebay but not sur ewhat they'd actually be like.
    As always, an direction would be appreciated.
    1996 Audi S6 Avant.
    1994 80 TDI - Daily Driver
  • max_s2
    • Mar 2006
    • 498
    • Country: Latvia
    The best I've ever seen
    • trackslag
      Account Disabled
      • Sep 2009
      • 171
      what brand are these?????
      • s2_bo
        • Oct 2005
        • 6067
        Vdo
        91 S2 coupé - RIP
        98 S8 - Luxury barge
        • Alam
          • Jan 2009
          • 18
          1,051 Followers, 1,181 Following, 266 Posts - See Instagram photos and videos from 9000 Rpm Classic Racing Team (@9000___rpm)
          • andy10v
            • 5996
            White VDO ones look good/blend it, about £50 on ebay
            Sold ABY-stock
            • s20ale
              • Aug 2004
              • 476
              I have a VDO guage same as this but in psi, £50 posted to your door if your interested.
              • gunman
                • Jan 2009
                • 660
                Thanks, I'd Ideally be looking fo one in Bar tho.
                1996 Audi S6 Avant.
                • Acidburn
                  • 13459
                  I have one same as in the pictures above that I will be selling in a couple of weeks, still in the box, used for around 20miles before I sold the car.
                  • gunman
                    • Jan 2009
                    • 660
                    could be interested in that, keep me in mind when you're selling
                    1996 Audi S6 Avant.
                    • philKS2
                      • Sep 2006
                      • 370
                      How do they fit... can you simply insert a T-junction into the hose that comes into the ECU???.. then run a spur off it round the back of the dash?
                      Also.. where's the fave place for locating the dial? Between the air vents?
                      SOLD !
                      • K Simmonds
                        • Dec 2007
                        • 7627
                        [QUOTE=philKS2;447037]How do they fit... can you simply insert a T-junction into the hose that comes into the ECU???.. then run a spur off it round the back of the dash?
                        Yep, that's exactly how one does it, really easy
                        The centre dash vent seems to be the favoured location.
                        1990 B3 2.0 80 quattro.
                        1992 C4 2.8 Avant quattro
                        1994 MTM RS2.
                        1998 B5 TDI quattro Sport.
                        2000 B5 TQS.
                        • GazzaG60
                          • 4133
                          personlly id take a hks, greddy, defi if you want accuracy.
                          anything under a 1'er may not be too accurate.
                          i use a defi BF boost. its electric so no feeding vac lines. it has a sensor that connects to the control box and is the t-pieced with a short line somewhere. cant remember. reads the same as the E-boost 2 and the ECU.
