NM Camshats,7A....
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    NM Camshats,7A....
    Hello¡¡¡
    The NM camshafts are much better for the RS2 turbo aplications over the ABY/3B/AAN ones true???? because they are more similar to the Adu ones true too???
    but with a correct maping the 3B intake cam + 7A exhaust cam would be the best??
    but whem the people says that NM cams are very good,they are meaning that we have to install both NM cams true??? or only the exhaust one??i
    I have the chance of buy the NM camshafts easily...., but i am not sure if they will work better in my 3B with all rs2 parts (excluding adu camshafts)
    now i have both 3B cams inside...and a spare 7A cams too...somethimes i think in install the 7A exhaust one but....
    pd: i will have to buy an adjustable cam??
  • Bram
    • Aug 2006
    • 2582
    What do you mean with Better and Best?
    A lot depends on how you want the engine to behave. Highest top-end power, early low-end torque, strong mid-range......etc.?
    Different cams deliver different results, also if you change timing of those cams.
    • Rocco
      • Aug 2007
      • 6393
      • Country: Spain
      RS2 turbo has a good mid range power true?? and then i think that NM camshafts are better than 3B/ABY ones ??
      • GazzaG60
        • 4133
        just use aby or adu cams on the rs turbo
          If you can get the NM cams then get them!
          • Rocco
            • Aug 2007
            • 6393
            • Country: Spain
            BUT adu cams are very expensive and i have not them
            3B inlet with 7A exhaust maybe fine
            aniway with my current both 3B cams the cars works perfect¡¡
            thanks for the help friends
            • Rocco
              • Aug 2007
              • 6393
              • Country: Spain
              OK Jamo, 150€ are a good price for them true??
                Yes considering how rare they are.
                • goodall
                  • Jul 2008
                  • 810
                  Looking at the sticky on various cam it seem 7a and nm are pretty much same just nm is 6 degree advanced for both exhast and inlet and less lift on exhaust. Adu cams seem to quite different from both 7a and nm
                  • Rocco
                    • Aug 2007
                    • 6393
                    • Country: Spain
                    and then the best cams choice for use the k24 7200 must be the origianals ADU cams
                    uf...and after all.... surelly that the cars will works perfect with any camshafts configuration....
                    • GazzaG60
                      • 4133
                      so nm is rare but basically the same cam as a 7a.
                      think most of this has been covered many times over in the past. id expect any of the above is good as long as its timed properly.
                        The timing is different, thats like saying the 3b cam is the same as 7a which I dont understand when people say it
                        They are better than stock, look at the posts Krists who has installed them with a 3071r and had very good results.
                        There is also the Kruemmer post which shows:
                        After many simulation and engine tuning I have find & test optimal value cams:
                        1 Best Street setup <450 hp (Best low end torque and HP)
                        EX NM 215 .0.1 duration -25 open BDC UT ; close after TDC OT 7 ,
                        IN NM 215 .0.1 duration 13 open TDC out; close after BDC UT 45
                        + RS2 Wheel 034 109 105B
                        • GazzaG60
                          • 4133
                          like i say if its timed properly. i dont know the cam spec but if like people say its the same lift and duration then its the same cam timed different.
                          you know my thoughts on this. i got the 7a ex cam in and its probly not as good as stock. maybe with timing wheels it may be.
