Supercharged S2 engine - Audi 90 transplant
  • simyboye
    • Nov 2007
    • 168
    Just a quicky though. Coil pack S2 or dizzy S2?
    Whats the better one to get? Hear its lots to replace the coil packs.
    • K Simmonds
      • Dec 2007
      • 7627
      Originally posted by simyboye
      Ah..
      Glad I found this site. Thanks for your help and advice on this.
      Right then, back to the turbo charger then. 400bhp.
      Whats the best way?
      RS2 turbo? Gt30 turbo?
      Remap - MRC
      3 core IC - Saab one off fleabay
      Bigger injectors? - RS2?
      Fuel pump? Which one?
      Thanks again!
      No worries.
      There's a few well proven routes to 400bhp, forget the RS2 turbo if you want a genuine 400+bhp, K26/27, GT 28, GT 30 will all do it and there's a couple of other very good options from other manufacturers. To run this sort of power safely you will need to rebuild the bottom end with uprated con rods and new shell's ect, especially if you want to make the most of the available torque.
      Use the search function on here to gain all the info you need and more, beware of spending a great deal more cash than you originally intended to
      1990 B3 2.0 80 quattro.
      1992 C4 2.8 Avant quattro
      1994 MTM RS2.
      1998 B5 TDI quattro Sport.
      2000 B5 TQS.
      • K Simmonds
        • Dec 2007
        • 7627
        The 3B distributor with the correct narrow roter arm will support 400bhp, much more though then seperate coils are the way to go.
        1994 MTM RS2.
        2000 B5 TQS.
