7A flywheel questions
  • A80Avant
    • 10873
    • Country: Greece
    Hi,
    if the dual mass flywheel is replaced with the 7A flywheel, are the same crank sensors for trigger tooth count used? besides the mechanical aspects of the replacement, is there anything else that needs to be done for the ECU to read timing correctly?
    thanks
    vasilis
  • a4kquattro
    • Feb 2005
    • 411
    Originally posted by A80Avant
    Hi,
    thanks
    vasilis
    7A will work. For VEMS users such as yourself I would recommend zero-verifying your timing with a timing light after the swap to trim out any slight differences, since the reference pin on the 7A is just a pin while on the AAN its a block of steel, so the position could be off by a degree or two.
    Marc Swanson
    Proprietor, EFI Express
    95.5 //S6 Avant
    90' Coupe Quattro V8 4.2L twin turbo
    93' //S4
    83' UrQ
    97' F250 7.3 diesel
    • A80Avant
      • 10873
      • Country: Greece
      ok that is great. just needed to know that info before buying the 7A flywheel!
      • A80Avant
        • 10873
        • Country: Greece
        by the way, i have emailed you for a 1.1.62 issue
        • Bram
          • Aug 2006
          • 2582
          I swapped the ABY DM wheel without issues for my new lightened 7A wheel. VEMS did not complain, or at least I did not notice anything.
          • A80Avant
            • 10873
            • Country: Greece
            did you use a strobe light to check the timing?
            • AndyP
              • 6049
              If I were you Vas, I'd get take the pin out and weld a block on like the AAN, you won't have to worry about the pin getting broken then. I'm going to look at doing this before I fit mine.
              • Bram
                • Aug 2006
                • 2582
                No, it worked without any issues. Maybe I was lucky :mischeif:
                  Yep that's what was done on mine
                    can't you just weld the pin in, or is that what you mean?
                    • Billman
                      • 4129
                      why should the pin brake?
                      Go Holset or Go RS4
                        Why is the sky blue?
                        They break, many many many reported cases of it after all it's a small pin in a high speed rotating mass called the flywheel
                        • A80Avant
                          • 10873
                          • Country: Greece
                          any photos of this done?
                          • Billman
                            • 4129
                            haha....nice!
                            Go Holset or Go RS4
                            • kwlw
                              • Sep 2004
                              • 1025
                              • Country: Lithuania
                              I would second to that. BTDT.
                              Sau
