Light blue Smoke
  • charlie
    • 447
    #31
    Hi Steve, could you specify PCV
    If its what ithink it is, would installing a breather filter help
    and secondly, i can understand how this fumes r sucked past the cold side when engine is running but surely they must go up past the MAF when engine
    is switched off. any opinions
    RS2 MTM
      The oil fumes cool in the intercooler forming droplets of oil i believe.
      Dont understand how it would be possible to get an oil leak on the cold side though.
      I'd agree with Audiman, sounds like the Valve seal have gone or the seal or the oil seal on the turbo.
      • SteveH
        • 4460
        Positive crankcase ventilation. A system used to pull oil vapour and combustion gasses back into the engine, rather than allowing them to escape to atmosphere.
        91 Modded 3B
        14 A6 Avant Black Edition
        • charlie
          • 447
          #34
          Thats what i thought steve. The oil consuption has subsided abit. My local
          Audi specialist is also abit puzzled. taking turbo off is stage 1. If it comes
          back as ok then head will be coming off again.
          On a brighter note just installed my home made heatshield. will be testing it
          tonight
          Exhaust gases after IC mod are smelling alot better
          RS2 MTM
          • charlie
            • 447
            #35
            Problem solved
            Finally found out the problem thanks to some good advice and new parts
            from Alan at Vagparts . I salute u gents.
            It was a faulty PCV. Amaising how something so small could cause months
            of lack of sleep. Now she flys
            RS2 MTM
            • RIX
              • Jul 2004
              • 229
              • Country: Denmark
              #36
              did you buy a new hose could i have the part number as i have similar problemes,
              thanks
              • charlie
                • 447
                #37
                thanks
                Pressure regulating valve 034 129 101 A
                Good luck hope it helps
                RS2 MTM
                • RIX
                  • Jul 2004
                  • 229
                  • Country: Denmark
                  #38
                  thanks where does it sit,does it sit on the out side of the engine.
                  • charlie
                    • 447
                    #39
                    When you look into ur engine, it is between the block and main radiator.
                    it looks like a half an orange but in black with two pipes coming out of it.
                    facing u will be the big flat end. One pipe goes down to engine block( check
                    u dont have a gauze on the block which sometimes gets blocked and might need cleaning). the other side goes all the way to rocker cover at the back
                    of your engine. This is to let ur engine vent its fumes but if valve is faulty it
                    will let oil through
                    RS2 MTM
                      I will have to check part no's, but i think lee had the same problem when he was at my dads garage meet. My dad managed to find an identical item from VW which was a fair bit cheaper. Iwll have to investigate it for you this weekend.
                      • DAVIDP20V
                        • Dec 2003
                        • 165
                        #41
                        i think i need one of these ! mine has started smoking on tick over when i start up in the morning. got any pics of what it looks like anyone ?
                        DAVIDP20V - 95' Polar Silver RS2 standard 315 bhp, forge diverter valve, Mark H mod and boost gauge..... and shes for sale.
                        • DAVIDP20V
                          • Dec 2003
                          • 165
                          #42
                          dont worry should be this yea ?
                          how much is it charlie ?
                            yup that is the one my dad got hold of, I will see if i can get the part no.
                            • DAVIDP20V
                              • Dec 2003
                              • 165
                              #44
                              greg i bet they are a very common part on most vag models i am sure i have seen one before !
                              • alg
                                • Apr 2004
                                • 1160
                                #45
                                David if its white smoke in the morning which goes away. Dont worry its just condensation in that drainpipe of an exhaust. I spent some time looking into this as mine does first thing in the morning.
                                If it continues with a warm engine or is blue or black WORRY !
                                I followed an RS blue onto the bypass last weekend. When he booted it to show me how fast it was, there was a puff of blue smoke. Thats something to worry about!
                                Dont think he frequents the forums although its a nice one.
                                Alastair
                                RS2
