Too much boost
  • xgordyx
    • Sep 2006
    • 379
    Hay Andy.
    Not tried new fuel pump yet, was thinking that or maybe fpr also.
    I think first thing i'll do is try a new / good sh MAF.
    I was hoping to try and get it running right in the next 2 weeks before i go back to work as next time home i'll be pulling the engine and having Aelred rebuild the bottom end. If i cant, while the engine is out it will give me a chance to give everything a good going over.
    There is a lot of things that need doing to the car, it's all just small time consuming things tho. I'll get there with it one day tho.
    • Knight Rider S4
      • 3541
      If you need a MAF i have some spare kicking about ...I would double check the green and yellow wire from the N75 is not earthed as this will cause max boost any gear at WOT
      93 S2 Avant Parting
      91 URQ RR
      02 A4 tdi Avant
      • xgordyx
        • Sep 2006
        • 379
        Perfect could you PM me with a price and paypal address
        • T2Andy
          • 1903
          I have a good working ABY fuel pump and basket if you need one
          • xgordyx
            • Sep 2006
            • 379
            Cool cool, i'll give you a shout if i need it, thanks
