Knock sensor plugs location
  • A80Avant
    • 10873
    • Country: Greece
    can someone remind me where those plugs are located and which colour plug is which sensor? im trying to find the photo for quite some time and cant!
    thanks
    vasilis
    They are on the firewall just behind the cylinder head, one will be green and one will be blue.
    The sensors are the physically same, the colour difference is just to differentiate the cable lengths
    • A80Avant
      • 10873
      • Country: Greece
      do you remember which one is the one that goes closer to cyl.1? should i cut the blue wire or the green wire???
        Why would you cut the plug?
        Yeah I took pictures when doing my car see below
        • A80Avant
          • 10873
          • Country: Greece
          i was just joking.
          i am going to fit the knock sensing cable marc made for me! so i need cyl 1.
          cheers for that, its the Green!
          • GT500
            • Jun 2006
            • 2181
            You want to be carefull when using the southern word CANT
            Rob..
            87 UR 20v ABY
            97 S6 Avant
            • A80Avant
              • 10873
              • Country: Greece
              hahaha
                Isn't the blue one (G66) too far forward? The Green one (G61) is for Cylinders 1 and 2, the blue one, 3, 4 and 5. Looks like the blue one is opposite no. 2. Shoudn't they be like this:
                  The picture is of diesel block not an ABY, ADU block. It's what you have to do to install them.
                    Okay. But the G66 (rear most) isn't going to be able to do its job (measuring pinging on cylinders 3, 4 and 5) sitting that far forward.
                      Thats's how it came from messer Pisobiker, I can't remember if the tapped boss behind it is actually used for the engine mount.
                      I'll see if I can move it on your advice
                      • EspenW
                        • Apr 2007
                        • 1534
                        • Country: Norway
                        Originally posted by A80Avant
                        i was just joking.
                        Any reason why you plug it into the sensor for #1 (and 2)?
                        On my KnockLite, I'm using the input from the sensor that listens to 3/4/5. The more cylinder coverage, the better, one would assume.
                        1994 80E Avant
                        1986 2L Golf 2 on Alcohol
                        • Bram
                          • Aug 2006
                          • 2582
                          Why would you need another knocking mechanism next to VEMS? Isn't VEMS firmware version 1.1.5x and up doing knock control of some sort?
                          Or is it not working well enough?
                          NB I use the headphones myself to tune VEMS at this moment on 1.1.27 firmware.
                          • GazzaG60
                            • 4133
                            sensor needs to be over a water jacket. thats the important part.
                            cutting into a shield is a no-no. the sensor wont work properly then. also keep the wire off water pipes and metal.
