Hi..I have a 1995 AAN URS6 with 50.000 Miles,,in have ben driving since some months but..I feel like the engine is missing some horsespower..beside the ridiculous
story given by Audi about the maximum torque at only 1900 RPM!!..pratically the engine doesn't feel as 230 hp until it reach 3800-4000 rpm..Unfortunally I don't have another AAN under my sight to compare with mine..I did a lot of tests in the engine..i checked the waste gate to assure was working..the timing belt it's new and the timing i's ok,the air pressure hoses are in good shape,the injector are checked and the fuel pressure is ok and also the quantity of gasoline in 30 seconds are in the specs..if I give full gas at 2500-3000 rpm i't like driving a 160-180 hp car..the turbo pressure it's ok,1.15 in overboost,
I have replaced the following things due of others sort of problems and because the engine was giving torque not in a clean progressive way but..it is stalling in some range of rpms..let's say..it's stalling from 2500 to 3000 rpm..from 3500 to 3800...at that range it runs nice but from 4500 to 5000 stalls again..it's like a "stairs" power generation..anyway the parts are 5 coils,the air mass sensor,2 knock sensors,spark plugs,bypass valve..(this was broken)...obviously the torque missing or stalls are not so exagerate.but who drives feels..it's like the ecu retards a lot the ignition.I also have tried to contact some friends with the Dyno..but unfortunally..in Sicily we not have the Dyno for 4wd cars..
