Water pump Q.
  • A80Avant
    • 10873
    • Country: Greece
    Water pump Q.
    Among the parts im going to buy, i have to get the water pump.
    there are 2 options.
    1) refurb pump from audi costing about 40GBP
    2) New part from audi costing about 140GBP.
    what would you do?
    i have already had a problem with a refurb pump which lasted about 2000Kms,then it started to leak and losing coolant...
    was that a one off thing,being unlucky or have anyone else had the same experience?
  • topsparky
    • Oct 2005
    • 2014
    what would you do?
    £140 for a water pump i'm sure it's the same as the vw t4 2.5tdi and they're only
    £40 ish brand new
    1. SHORT SHIFT KIT
    2. PORSCHE CAYENNE CALIPERS
    3. H & R SPRINGS
    4. BILSTEIN SHOXS
    5. NEW BUSHES AND HP2 STRUTS
    8. fmic fitted
    • repo
      • Dec 2004
      • 893
      c) buy a new Graf pump with metal propeller for 70 eur.
      • johne
        • Apr 2007
        • 1405
        Buy a new one from GSF or ECP. I've fitted a new one from GSF every time I've changed the timing belt and had no problems.
        John
        • A80Avant
          • 10873
          • Country: Greece
          thanks for the anwers,
          the graf one does not have anything for the rs2 model. Only for ABY. is that my choise?
          etka gives the ABY PN as 054 121 004AX and ADU: 034 121 004B
          Interestingly enough, the code 034 121 004 (without the B) comes up in 2.1 liter I5 engines and older models!!!! seems to me that the ABY one should be better(?)
          any known differences before i order the aby one?
          • johne
            • Apr 2007
            • 1405
            AFIK the RS2 water pump has a different number of teeth to the ABY one and requires a different length timing belt. I suggest you check the posts on here about it.
            John
            • GazzaG60
              • 4133
              id just to to audi and get one.
              pretty sure it was about 30-40 quid for aby pump. oil pump is mortgage.
              avoid aftermaket with plastic impeller.
              • repo
                • Dec 2004
                • 893
                I see absolutely no reason to use ADU parts and pay the enormous extra they charge for the belt and the pump on the marble desk for them. ADU has smaller water pump drive, and therefore shorter timing belt.
                I would choose ABY parts without a doubt. You just need to mind the cam timing, if You had ADU parts before. I assume You already have adjustable timing gear, so it should not be an issue.
                Some OE pumps come with plastic prop, and I would definately not use one.
                • A80Avant
                  • 10873
                  • Country: Greece
                  no, i have all ADU parts, no ABY parts on the engine, so cam gear is ADU, cams are ADU and water pump is ADU.
                  only difference is oil pump AAN from 034 but no problems using that so far.
                  so do i have to get other parts to fit the specific water pump?
                  • lind4hl
                    • Jul 2008
                    • 2465
                    ADU has 1 less "blade" inside so it flows more water, faster...
                    • A80Avant
                      • 10873
                      • Country: Greece
                      audi sells the 30-40 GBP ones that are reconditioned. that is my point. its the reconditioned ones i dont trust
                        It's 3 teeth
                        RS2 has 26
                        S2 has 29
                        I'm using the RS2 flows more water good for cooling on a modified car.
                        • lind4hl
                          • Jul 2008
                          • 2465
                          Originally posted by Jamo
                          It's 3 teeth
                          RS2 has 26
                          S2 has 29
                          :corey:
                            :corey:
                            That's no way to talk about your alloys
                            • A80Avant
                              • 10873
                              • Country: Greece
                              so really the suggestion is to go to for the new part from stealers?
