I need some vag com data logging from a stock aan car.
Each chanel will help 00 01 etc.
I have a boost problem(only 0.8 bar).
I can not find a leak,and on the aux gauge i can read at full throttle a 0.5 bar at 2500 rpm over 3000 a 0.9 and after that it goes down at a constant 0.8
i want to see if something tels ecu to low boost.
How reacts the boost gauge in case of boost leaks?
Mine is going up to 0.9 and fast to 0.8 and it is stabil at 0.8
A boost leak should be a 0.8 and not more?(full throttle speaking)?
