Miss At highboost level under load
  • coldshots6
    • Oct 2009
    • 16
    So my car is RS2ued real time tuned from Minhea and lately it has been doing this weird boost problem. If i stomp on it at say 45mph or 50mph in third gear the boost pressure climbs to 30psi and bam big buck.I let off a little and the car goes fine but at about 25psi. It use to just go.The same thing is true for 4th gear at like 60 or 70mph. I have replaced spark plugs because they had 10000 miles on them. I have check for vaccum leaks and boost hose leaks thinking i am hitting over boost cut out but i have not found anything?
  • Costash
    • 878
    • Home: Romania Current: United Kingdom
    Check coil packs.
    • bsh
      • Aug 2007
      • 43
      • Country: Norway
      Try to reduce the electrode opening to 0.6 mm
      • stevieyid
        • Apr 2005
        • 2251
        Sounds very similar to my problem. First and second gear fine?
        • A80Avant
          • Sep 2005
          • 10873
          • Country: Greece
          dont do anything to the spark plugs. The bosch ones cannot be adjusted anyway and they are 0.6mm width anyway.
          this is likely to be a coil, spark plug pipe or POS problem.
          It could also be a tiny boost leak leading to overboost and then cutting out.(fuel cut). Is the bump abrupt and severe? or just a mild misfire?
          • coldshots6
            • Oct 2009
            • 16
            i think i finally found it the hose under the throttle body t hose... was cracked and if i flexed it it would leak a little. STill get a miss if i nail it in 4th gear at 65 mph but i think at that instant i am hitting over boost cut out. My boost guage slams into 30psi and that is as high as my guage reads. No other boost leaks found though...
              Make sure and reset ECU after fixing boost leaks... is it bringing up any fresh fault codes ?
              • coldshots6
                • Oct 2009
                • 16
                no codes. The only time i get a code is if i don't shift fast enough and hit the limiter. I have not reset the ecu yet. i will do that
                • coldshots6
                  • Oct 2009
                  • 16
                  I re-set my ECU no change. It feels like it hits over boost cut out. I think i am going to fill with race gas and see what happens. I am also going to try running on my race gas program instead of my 93 octane too and see what happens.
                  • coldshots6
                    • Oct 2009
                    • 16
                    edit. it only does it at 65mph when i floor it in fourth gear and 80-85 in 5th gear. If i am doing 70mph it doesn't do it same with if i am at 95 mph
