TPS Measurement
  • TPS Measurement
    Still trying to sort my lack of low rev boost.
    Throttle position sensor only made 2470 ohms @WOT and Paul's site says it should make 3600 ohms. could this be the problem?
    Paul
    S4 2.7 Twin Turbo, with a few mods
      I think 3600 is a mistake as I just bought a new one and it made 2470 too
      RS2 chip by mihnea,PKM short IM, forge dump valve, 3" custom stainless exhaust, 18"X8" Porsche 996 rims, conti contact 245/35 Front 225/40 Rear, QR sport top mount, Powerflex bushes, aloy sub frame bushes, neuspeed 19mm RARB,Hard tranny mount, V8 torsen on RS2
        thanks for the reply. I though every 1 had gone home
        I will pm Paul and ask
        cheers
        Paul
          Mine shows 2650 ohms at WOT (between pins 2 and 3). At idle the resistance between pin 2 & 3 is 970 ohms.
          Markus
          '94 Kristallsilber-metallic S2 Avant.
            The 3600 figure comes from the manual and yes it is artificially high.
            Whats the symptoms then ?
