Ok car wouldnt start at the weekend. Its a aan. Its getting fuel but no spark. When i hit the ecu a tap car started fine. Then hitting the ecu a tap when running gives a missfire and a stall. So looked in ecu and it looks fine. Chips ok in socket etc. Now i put the ecu back in car wont start. But starts ok on another ecu. So it is the ecu for sure not the wires or connection. Where should i look? Vag com says engine speed sensor fault when it wont start. Cheers des. Ps anyone a aan or aby ecu for sale? Cheers
