3b engine cut?? any advice
  • jonnaz
    • Aug 2009
    • 158
    The engine has been rebuilt sounds sweet..
    however it is cutting out sometimes as i pull away at low revs below 2k. the car has an electronic boost controller so i have removed the wgfv (havnt got it plugged in) the car will also only boost to 1 bar then cut out and it will only boost to 1 bar if its a steady acceleration no if booted. i unplugged the boost controller and on mechanical boost it will somtimes cut at low revs when pulling away but not if i boot it maby just because less boost.... it can also take a few secons to pick up when pulling away, and can search when driving along at 2k revs.
    car was running good before rebuild. well before engine siezed.
    i have taken the maf out and going to clean it will also clean the isv.
    will check for boost leak but shouldt matter as there is no wgfv.
    has anyone got any idea what could be causing it or anything that will fix it.
    thanks
