KKK turbocharger identification request
  • fanta
    • 7
    I've come across a KKK turbo and was wondering if anyone knew the specifics of this particular combination. I believe it to be some form of hybrid, but am unfamiliar with KKK chargers (possibly a K27/23?). Information collected is as follows:
    Identification marks:
    Compressor: 5327 151 5790
    Center Section: 5327 151 (0932 0090 0080?) Last set of numbers was difficult to make out, 0080 seems most likely.
    Turbine: 5223 900 0570
    16 520186 S
    “16” in turbine inlet
    Dimensions & Details:
    Compressor
    ~2 5/8” inlet, tapers to ~2”
    Stepped twelve-blade wheel
    1 5/8” outlet
    8-bolt connection to center section
    Turbine
    2 3/8” x 1 15/16” inlet, stepped to a smaller flow area.
    Twelve-blade turbine wheel
    2 5/8” turbine outlet
    4-bolt exhaust flange
    Connected to center section by six bolts
    “T9” marked on turbine wheel bolt/nut/center.
    Rough idea as to its flow characteristics? Any insight on the matter would be greatly appreciated.
  • audiman
    • 4827
    Pictures ?
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
    • fanta
      • 7
      Originally posted by audiman
      Pictures ?
      It was previously on a rotary engine. More pictures are to come
      • fanta
        • 7
        Exhaust inlet
        • fanta
          • 7
          One left
          • fanta
            • 7
            • Audi Parts Guru
              • 1317
              What would you like to fit it to ?
              • fanta
                • 7
                If deemed so, it would be mounted onto a miniscule 1.8L I4. I really would like some maps to help gauge what it would provide if possible
                • audiman
                  • 4827
                  Looks like that thing will be way to big for a 1.8 engine. It would spool up at 6k or so!!
                  Audi UR Quattro
                  • fanta
                    • 7
                    Bump.
