Paul N: Small problem with your POS diagram
    Paul: I was updating my POS info on quattroworld this AM
    ( http://forums.quattroworld.com/s4s6/msgs/15284.phtml )
    and was going to include your AAN/ABY/ABY POS wiring diagram but then realized that the diagram is wrong for the AAN. The wire colours for the AAN for cylinders 1 through 5 are green/white (same as you have), violet (same), black/grey stripe (not black/blue), black/yellow stripe (not red/black), black/white (not green).
    I am basing my colours off the diagram from my 1.8t coil pack DIY (attached with your diagram as a jpg). I suggest you add a column for AAN wire colours or remove AAN from the title (prefer the former to the latter). It is a great diagram, just a bit off for the AAN.
