I've just discovered a hairline crack in the top of the main radiator... it's just seeping coolant, but I'm going to change it asap.
The crack is close to the top hose.
Is this common or is this a precursor to something more major????
There's no great coolant loss, but there does seem to be evidence of coolant seep from both pipes prior to the crack appearing. Extra pressure finding it's way into the cooling system or just panic over nothing ?
Any suggestions appreciated.
thanks
Raymond
thanks
Raymond
that's a relief. I was a bit concerned that it may have been boost finding it's way into the cooling system bumping the pressure up causing the overspill and crack... what imagination can do !
with all the movement(through not having a working top mount). Cost me a new radiator, and 4 hours of scraping knuckles, and an Irish James Bond smoke screen in front of my car stuck in a traffic jam while Xmas shopping
Unfortunately A Flux were only ones to come in under a grand, and they want to know anything and everything bout the car, which, I suppose, is their right, but more work for me.
