Plumbing in the boost gauge
  • jubjub
    • Nov 2003
    • 1239
    Is this the pipe i should be T-ing into
  • Pete_RS2
    • 800
    Here's where I tee'd mine Dean.
    Now RS2'less
    '99 VW Passat VR5 Sport
    • Audi Parts Guru
      • 1317
      Peter, where did you get all of the bits from to plum in the boost gauge ?
      I've got the white VDO gauge sitting in my drawer
      S2 Avant......fully loaded :rock: :bow: Slipper Wagons Rule !!!!!
      • SR71
        • Apr 2004
        • 330
        Out of interest, if the vac line that is indicated on this photo becomes detached, from the piston(?) on the left hand side of the picture, what would be the effect?
        What is that piston(?) part?
        Any tips on how to get the ECU off its perch?
        Cheers.
        00 Audi B5 S4 MRC550
        08 RRS TDV6 HSE
        03 Kawasaki B2 ZX12R 1287cc
        • jubjub
          • Nov 2003
          • 1239
          Nice one matey So that is right......Where did you end up putting your gauge
          • Beetie
            • Oct 2003
            • 1517
            Take your pick Dean, thers been a few different places they have been put now, so I think its personal preference.....
            On another note, have you moved the cc unit to somewhere else on the newly refurbed manifold?
            Was a '93 3B, Dont ask now tho......
            • jubjub
              • Nov 2003
              • 1239
              CC unit Is that the bit i had mounted wrong
              • Beetie
                • Oct 2003
                • 1517
                Cruise control....
                • jubjub
                  • Nov 2003
                  • 1239
                  Cruise control....
                  Ooops No same place.I will have to move the CC unit tho when i get round to putting a catch tank on....
                  • Doug_RS2
                    • 3847
                    Why? Mine doesn't get in the way of my catch tank.
                    • jubjub
                      • Nov 2003
                      • 1239
                      Might have my wires crossed here I was on aboutthat getting in the way of the catch tank...Is that where yours is? I have never seen your car
                      • Mark Halligan
                        • 2001
                        Dean,
                        if thats your CC it looks like it is non standard, nothing like mine anyway.
                        Mark.
                        Mark - Modded
                        • Beetie
                          • Oct 2003
                          • 1517
                          Originally posted by Mark Halligan
                          Dean,
                          Mark.
                          Yeah we worked out that its non standard, using the standard stalk inside the car though....
                          • jubjub
                            • Nov 2003
                            • 1239
                            Dean,
                            Mark.
                            Right Mark! It is/was fitted aftermarket.I had at a look at yours and Sals at GTI, and it looks as though it is almost definately in the way
                            • Pete_RS2
                              • 800
                              I put mine in the centre vent you gave me Dean.
                              Paul,
                              The end piece you need for that VDO gauge is a 1/8" NPT. You can get a fitting kit with the end piece, T-piece, vac hose & silicone joiners from Demon Tweeks (Part No. LMA001/B) for about a fiver. HTH.
                              Now RS2'less
