034 AEM old air intake will this fit an S2?
    Be a good option if it did
  • GazzaG60
    • 4133
    not sure.
    if you want i can take a pic of mine how it sits and the pipe. its 2 mins to remove.
    id expect the position of my turbo and no aircon may make it different though.
    its basically a filter bout 6 inch diameter and maybe 10-12 inch long. its down behind the ic where an aircon pump may sit. a pipe goes up then across and a knock together 2 silicone hoses to fit the turbo.
    • dest
      • 4287
      Bloody expensive for a filter a couple of bits of pipe?!
      • GazzaG60
        • 4133
        the nature of kits like this dest. i gotta agree.
        i recollect the jabbasport induction kits being costly for the G60 and it was a jetex filter and a sheet of metal.
        mine cost me nothing IIRC so i was lucky. my mate was kind enough to let me have it from his old parts bin.
        id measure up the size of filter you want jamo and speak to jetex.
        id also check summitracing.com for the aem filter price.
          I've got a 4x9 AEM filter to fit to the car, I was more interested in the piping ( not that i'm going to buy the 034 stuff ) and i'm looking at various filter placements.
          I have aircon on my car as well
          • terrybullwon
            • Mar 2006
            • 8782
            Not really when you take into acount the price of machine work and aluminum bends. Having built my own aluminum induction track I can say I used at least 3 4" elbows and they are not cheap!
            Chef
            • GazzaG60
              • 4133
              little more restricted on space than me then but not sweating your back out in summer.
              placing lower like i have helps with heat too.
              the headlight is in the way a little though.
              • terrybullwon
                • Mar 2006
                • 8782
                Unless you go through the wing
                Chef
                • GazzaG60
                  • 4133
                  yep. did on the corrado. worked well. used the wing as the airbox with a cone in there.
                  its a bit tight on mine to do that i think though and not required either.
                  • lind4hl
                    • Jul 2008
                    • 2465
                    Ditto!
                    as soon as people start making things themselves, they see how "cheap" and "easy" it actully is to buy finished stuff..
                    But who´s said that is fun?
                    • terrybullwon
                      • Mar 2006
                      • 8782
                      Originally posted by lind4hl
                      Ditto!
                      Exactly!!!
                      Chef
                      • Sweeper
                        • 1317
                        • Country: Latvia
                        I can sell the dahlback reverse pipe with the samco hose if anyone interested
                        50EUR + shipping
                        Vadim.
                        New engine (mechanical PKM head) , Alcon 332mm brakes , Pauter rods , Mahle pistons, GT30R , kw v2 sucpension , new exhaust. 608HP. For SALE !
