HELP engine cutting on boost!!!!
  • [RPM]
    • Dec 2009
    • 229
    • Home: Portugal Current: Ireland
    the car was ok but today every time after the car was serviced
    when the boost dial hits +0.5bar the engine cuts
  • stevieyid
    • Apr 2005
    • 2251
    Overboost protection. Check the usual maf, boost leaks etc
    • [RPM]
      • Dec 2009
      • 229
      the car just came from the garage from changing alternator brake fluid and puting G12 in the cooling sistem.
      could they done something???
      • [RPM]
        • Dec 2009
        • 229
        but I think its not overboosting... the dial shows .5bar when cuts
        • [RPM]
          • Dec 2009
          • 229
          just whent for a spin and now its ok.... boost's to 1.3 no problem...
          could it be because the fan was working and the temperature showing 93 celcius and the ecu cuts ?
          • Gazjen
            • Oct 2008
            • 223
            Mine does a similar thing if its left for a few days it misses really bad on boost but if I drive it to work (30 miles) when I drive home its fine! and goes like stink I think my problem is my coil getting damp in it and then drying out with the heat from the engine bay when its driven again
            URQ 20vt converted
            80 quattro saloon with on going a V8 transplant
            • rsmaku
              • 20
              If its a 3b engine, check the distrubitor cap, it may cause misfire. Misfire long result is bent rods. Check in search for" 3b misfire" or smth.
              Sorry for bad english, im bit drunk of beer
              • [RPM]
                • Dec 2009
                • 229
                mine is a ABY
                mine is not missfiring
                every time the boost gage showed 0.5 bar it would cut. the temp gage was showing
                94 +/- celcius
                later on whent for a spin and the car is boosting normal 1.2bar
                • rj scotty
                  • May 2006
                  • 2195
                  Give the TPS and MAF conectors a clean
                  Always works for me !
                  BUT I DON'T WANT A NEW CAR!
                  1995 S2 Avant, Volcano Black
                  • [RPM]
                    • Dec 2009
                    • 229
                    will do
                    thank you
                    • Rusty
                      • 18953
                      Overboost protection stops it from overboosting, it doesn't mean that it is shown more pressure on the dial, a more than ambiguos name but a commonly used forum term to describe what the ECU does.
                      Basically the duty cycle for the WGFVand the pressure that is being attained are substantially different due to a pressure leak and so the ECU gets in a piss and stops the boost, thus returning to the factory setting of 0.4Bar. It's a safety thing, stops the turbo working too hard and splattering itself all over the engine bay if you've got a leak, can also be triggered by a dodgy MAF and temperature sender.
                      More than likely, the garage have moved a pressure hose joint when doing the work and it's now leaking.
                      Did they take off the front crossmember for any reason? IC O ring sounds like a likely candidate if they did, check out the numerous Mark H threads, that'll solve any issues there. Otherwise, you need a pressure testign kit to get it all working correctly, will get you a few ponies too if it's been leaking for a while, it'll feel like a new car when all sorted
                      • [RPM]
                        • Dec 2009
                        • 229
                        they change the coolant and the alternator don't think they needed to take any pressure hose but I'll check it
                        the car has a mrc chip so I dont know whats the correct pressure for that remap
                        • Rusty
                          • 18953
                          Either 1.2 and 1.5 depending on high or low pressure variant, dropping to about 0.8 at the red line.
                          • [RPM]
                            • Dec 2009
                            • 229
                            tks rusty
                            looks like 1.2 and then drops
