7A Cam on Home fried ABY
    I've been reading up across the forum and there seems to be a great deal of interest in the 7A / NM cams.
    Being that the S2 is my first "dual" cam car you'll have to bare with me.
    Would there be any point / gains in fitting a 7A exhaust Cam on a ABY with the patent Home Fried ECU?
    On top of that would replacing both Cams be worth a future mod?
    My only conceren is concerning the timing and would the car require verniers?
    Of course this is all hypothetical and i would never consider doing such a thing.
    Jamo - I have to be totally honest here - I have not tested the homefries with the 7A camshafts. I really dunno if you'd see a benefit. My gut feel says its not really going to give extra performance as the extra lift it creates in the valves is more applicable to RS2 turbo applications which are forcing that much more air into the engine.
    Either way - you would not need a vernier pulley, but one is available if you like shiny anodised parts. Think MarkH sourced one from Piper or Kent - the Blingmeister that he is
    If there was extra performance to be had from the 7A cam on a K24 engine, then the chips would probably need a tweak to get any benefit. Maybe Mihnea has experience of this config, but you generally only see the 7A cam going into the RS2 installations - simply cos its cheaper than the RS2 one.
      Cheers for that Paul, was a curiousity thing, i'm sure a few other people have thought the same.
      Hmm RS2 turbo only........................... maybe in the future if i rob a bank.
      • WabTheKing
        • May 2004
        • 2567
        When everybody say's 7A cams do you mean cams out of an audi 7A engine? i have a spare 7A head you see
        • SteveH
          • 4460
          Yup the 7A cams are out of the NA 20v motor
          91 Modded 3B
          14 A6 Avant Black Edition
          • Doug_RS2
            • 3847
            Can you take some pictures of the 7A water manifold under the inlet manifold?
            • martinjs
              • 3205
              7A's have a smaller water manifold, only has one entry point into the head.
              • caterpillar
                • 2480
                the 3b engine have the little water manifold too. they DO put 7a cams in 3b engines,but the put a modifyed intakecam from 7a to exosplace on 3b..... tuned cam to audi: www.catcams.be
                • audiman
                  • 4827
                  I have both 7A cams in mine, no difference in power until it was mapped. Then I lost out on bottom end torque, but gained higher up. The duration is longer as well as the lift being more.
                  Tom C - www.rcmr.co.uk
                  Audi UR Quattro
                  Audi 100 C3 2.0 5 cyl 115ps
                  Audi B5 RS4 645ps 911nm
                  • caterpillar
                    • 2480
                    P.O. rods, pauter may be,but a cheep alt. is stenparner in motala in sweden,ive got the tlfnumber,but can i put it on the forum?
                    • caterpillar
                      • 2480
                      audicams or other vw www.catcams.be
                      • Kroegarn
                        • 92
                        Was it worth it? I can´t decide if it is worth to have even less bottom end. I´m missing my bottom end (from the K24) now with the K26/27-#8/54mm. Although not properly mapped yet.
                        Or was the loss of bottom end torque motivated by the high rpm power??
                        /Mike
                        /Mike
                        S2 RS Avant@355hp "For sale"
                        A4 Avant TDIq@170hp
                        Datsun 240Z@550hp
                        BMW M3 race car@321hp
                        Garage
                        • audiman
                          • 4827
                          High end gains, but not a lot. Depends on how far you want to go. There isnt that much loss bottom end.
                          Audi UR Quattro
