Ever since I bought my car, it’s boosted to 1bar, I always assumed it had a chip or a spring. Some investigation a while ago revealed it had neither, so I fitted some chips designed for 1bar boost and the car ran fine. Further tests have revealed that despite having a stock spring, it still boosted to 1bar with the WGFV unplugged, it also gets almost full boost on part throttle. The wastegate cap still has the tamperproof seal in and there are no spacers on the spring to preload it.
Last week I fitted another ECU with an ABY MAP and chips for 1.4bar boost, but it wouldn’t boost over 1bar. So basically I can’t get it to go above or below 1bar. I’ve since proved the turbo will do it by fitting a stiffer spring to get it up to 1.2bar.
It's been leak tested, has a new WGFV, new divertor valve and has no codes on VAG-COM.
Any ideas what could be causing this?
