I have always used V-power or tesco 99 fuel unless I could not get any then and only then would I put 95 Ron petrol in my s2.
One of these time however was last week and I did not notice when booting it the usual lack of power that I get with lower octane petrol .
My conclusion was that maybe as it was sub zero temps night and day that this had meant that the ecu had not had to retard the ignition as there was no knock at all detected .
Anyway after thinking this I decided to keep putting 95 Ron in the S2 and see how it was .
I have been running it on 95 Ron now for nearly 2 weeks and it flies just as good as ever, so until the weather warms up or I notice the usual drop in performance I'm going to save some money.
Also I'm getting I few mpg higher wile cursing and think that this is as the lower octane is getting the bang going quicker and making better power , this makes me think that the timing is not advanced enough wile cruising in very cold weather on 99 Ron fuel .
Maybe if this can be checked and verified by a few people then a tweak in the map for very low temps for cruising could save us all some money .
For ref my car is home fried ABY avant.
Has anyone else tried this and if not maybe you might see if it is the same for you
99 Tesco appears to alway run the best in mine though I notice V-power is also now 99 octane..
because here in SPain the best fuel for sale it is only with 98 Ron octane
and i´ve heard that in Germany for example the 104octane it´s available in some fuel stations
